hugzz Posted March 12, 2019 Posted March 12, 2019 Hi all I have moisture and water getting into my front headlight on my Q5 is there a way to fix this ? Or do I need to replace the front headlight with a new light and would anyone know if this would be covered under warranty
DTR Posted March 24, 2019 Posted March 24, 2019 Not sure if this would be under warranty now but check the caps at the back of headlight are all tight, replace with a new headlight if you can't find the problem as it will end up going for your xenon bulb.
Dan3222 Posted March 26, 2019 Posted March 26, 2019 It would be worth seeing if warranty covers light unit. If it doesn’t you can drive the water out by using tin foil (unless it quite full of water) open bonnet and wrap tin foil around the lense of the light. Turn on lights, probably with engine running. Leave on for 10 mins. Switch lights off. Remove the tin foil. You will have a dry light. Any condensation will have been forced out.
hugzz Posted March 26, 2019 Author Posted March 26, 2019 hi dan Thank you for the great tip, i will give it a try in the morning and let you know cheers
