Apologies if I am repeating a common question. If that is the case, please do put me in the right direction!
The remote keyfob on my new (used) Audi A3 (55 plate) will open the boot and lock the doors but will not unlock. Instead, I have to unlock the door directly with the key and quickly turn on the ignition to prevent the alarm from sounding (usually within 5-10 seconds).
Is this a common problem? Could someone recommend a course of action and rough pricing to expect?
Thanks in advance!
Daniel
  • 4 weeks later...
Thanks in advance!
Daniel
Expand
I had the same problem, although the tailgate wouldn't open at all. turned out it was the fuse controlling the body control module. worth a look ?
Thanks in advance!
Daniel
Expand
Hi,
I had the same problem, all I did was opened up the fob removed the battery and reconnected and it worked!!
Good Luck
Hi can anybody help me!! Today i was cleaning my car out and i put my drivers side window down when i come to drive it my window wouldn’t go back up and on the dash it was saying my door was open but the door wasn’t and when i come to lock it with the keyfob it locks ever door apart from the drivers door as anybody ad this  issue thanks
A mate sed it could be the door control module that’s gone do you fink it could be that. Thanks
All fix now lads thanks it was a few wires that snapped on the door loom
