JSG Posted April 24, 2019 Posted April 24, 2019 Hello from a newbie and learned advice appreciated. Have a new Q7 and swapped over a Next-Base Dash-Cam used in my last car. Used hard-wire kit which has piggy-back fuse adaptor. Seems all fuses (passenger foot well) are constant and so Dash-Cam on all the time. Last car had switched fuses which went off when ignition off. Does anybody know if current Q7 has any switched fuses? Dash-Cam leaflet says has a cut off if battery level very low, but not keen to risk. Thanks in advance for any advice.
niedzial1983 Posted April 26, 2019 Posted April 26, 2019 I have mine wirred in on my a6 c6 to the heated windscreen sprayers . Its only on when ignition is on. But the only way to check is to get a multimeter and check voltage on each fuse with ignition on/off
Thrillridesphotography Posted November 21, 2020 Posted November 21, 2020 I installed mine on the parking sensors fuse
