Got these codes and I am confused....kindly help
Petrol (ALT - Motronic - MT/AT)
DTC Description
No fault codes
No fault codes
18010 - +30 voltage
- Intermittent
16500 - Engine Coolant Temperature Circuit Range/Performance Problem
- Intermittent
17700 - Characteristic field controlled thermostat; open circuit
- Intermittent
18062 - Fault codes in instrument controller
- Intermittent
17953 - Throttle control unit; malfunction
- Intermittent
18017 - Shutoff activated on crash
- Intermittent
16705 - Engine speed sensor input circuit incorrect signal
- Intermittent
17927 - Camshaft adjustment, bank 1; malfunction
- Intermittent
17947 - Clutch pedal switch; implausible signal
- Permanent
18043 - CAN, engine/AC communication; missing or faulty signal
- Intermittent
18047 - Accelerator pedal sensor; implausible signal
- Permanent
Brake (ABS/ESP - Bosch 5.7 - MT/AT)
DTC Description
00287 - Rear right wheel speed sensor
- Short circuit to positive or open circuit
- Permanent
01826 - Steering angle sensor, +30 voltage
- No symptom
- Permanent
01314 - Engine control unit
- Check fault codes
- Intermittent
Instrument (Instrument - Diagnose - Gasoline (Petrol))
DTC Description
01039 - Sensor, coolant temperature
- Intermittent
00668 - +30 voltage
- Supply voltage too low
- Intermittent
01334 - Rear Right Door Module
- No communication
- Permanent
01333 - Rear Left Door Module
- No communication
- Permanent
01304 - Radio
- No communication
- Intermittent
Climate (Climate control - Climatronic)
DTC Description
00797 - Fotoconducter sunlight
- Short circuit to ground or open circuit
- Permanent
01809 - Step motor temperature damper, left side
- Blocked or no voltage
- Permanent
01810 - Step motor temperature damper, right side
- Permanent
00716 - Recirculation flap position
- Permanent
00819 - A/C pressure sensor
- Intermittent
- Permanent
Immobiliser (Immo/Instr - Immo 3)
DTC Description
- Intermittent
00668 - +30 voltage
- Intermittent
- No communication
- Permanent
- No communication
- Permanent
01304 - Radio
- No communication
- Intermittent
Restraints (Airbag - Airbag 8.4 - Limousine/Avant)
DTC Description
00588 - Airbag squib circuit, driver
- Above upper regulation limit threshold
- Intermittent
Multifunction (Central electronics - Central electronics - Highline)
DTC Description
00987 - Lamp, left brake light
- Circuit failure
- Permanent
00526 - Brake light switch
- Intermittent
Multifunction (Convenience system - Diagnose)
DTC Description
- No communication
- Permanent
- No communication
- Permanent
Multifunction (Steering wheel electronics - Diagnose)
DTC Description
- No communication
- Permanent
- No communication
- Permanent
audiss.pdfFetching info...
