Rycka Posted May 14, 2019 Posted May 14, 2019 Hello i got Audi A4 S-Line Estate 2010 2.0TDI Automatic gearbox (code LLA) i got problem with gearbox when i put in Drive it drives but when i put in reverse it drives but it feels like clutch is slipping so i scanned gearbox ecu and found 9 faults so i deleted 8 of them but 1 still stays on and it says ''P1 74200 Active/Static clutch torque adaptation, adaptation limit reached'' and gearbox makes some noise so maybe somebody had this issue and knows how to fix it? i think maybe i need to change clutch discs? maybe its an easy fix? and when i bought this car on the service book it says that they have put new flywheel in the gearbox
