A6 3.2 quattro fault codes
QuattroMark
I am slowly resurrecting a 2005 A6 3.2 quattro which has stood for 2 years -
Obviously its had to have a new battery - removed all plugs and did compression tests - everything was in order -
She fired first turn of the key!!!
A tiny bit lumpy but hey - she started!
I have managed to get rid of 99% of the fault codes, but I need a bit of help with the following:
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 4F1 910 559 N    HW: 4F1 907 559
   Component: 3.2l V6 FSI         0010
   Revision: --H15---    Serial number:
   Coding: 010D0003190F0120
   Shop #: WSC 02325 785 00200
   VCID: 3668EC774105EBFA37-8062
3 Faults Found:
005715 - Please check DTC Memory of ABS Controller
               P1653 - 008 -
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 253282 km
                    Time Indication: 0
                    Date: 2005.02.01
                    Time: 13:18:29
             Freeze Frame:
                    RPM: 704 /min
                    Mass Air / Rev.: 152.6 mg/str
                    Temperature: 46.5°C
                        Idle
                    Load: 22.7 %
                    Speed: 0.0 km/h
001632 - Intake Manifold Tuning Valve Control Circuit (Bank 1)
               P0660 - 009 - Elect. Malfunction
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 253282 km
                    Time Indication: 0
                    Date: 2005.02.01
                    Time: 13:18:31
             Freeze Frame:
                    RPM: 704 /min
                    Mass Air / Rev.: 147.2 mg/str
                    Temperature: 46.5°C
                        Idle
                    Voltage: 13.77 V
                    Speed: 0.0 km/h
005634 - Power Supply Terminal 30
               P1602 - 008 - Voltage too Low
             Freeze Frame:
                    Fault Status: 01011000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 51.0°C
                        Engine Off
                    Load: 0.0 %
                    Speed: 0.0 km/h
these faults will not clear - anybody help?
