trickyd400 Posted June 23, 2019 Posted June 23, 2019 Hi, I have replaced the engine speed sensor as I got a P0321 error, implausible signal, short to plus. I have changed the sensor with a new HAAS one, and had the ECU tested by ECUTesting ltd, and this came back as no fault found. I have checked the wiring for continuity and shorts to positive and ground and all checks out as expected. What I want to do now is test the old sensor I took out to see if it still good before I try changing it for an another new one from a different supplier. VCDS reports zero engine speed whilst cranking: (files attached) I'm pulling my hair out here.... help! Car is 144,000 miles (due a cambelt) A3 S-Line 2.0TDI 3dr Quattro Engine is BMN and 170bhp Saturday,22,June,2019,20:11:00:39744 VCDS Version: Release 17.1.3 (x64) Running on Windows 10 x64 www.Ross-Tech.com Address 01: Engine Labels: 03G-906-018-BMN.clb Control Module Part Number: 03G 906 018 DN HW: 03G 906 018 DN Component and/or Version: R4 2.0l PPD1.2 1247 Software Coding: 0000172 Work Shop Code: WSC 00353 210 91454 VCID: 74E0079217206FE1FD-8020 1 Fault Found: 000801 - Engine Speed Sensor (G28) P0321 - 006 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00010001 Fault Priority: 5 Fault Frequency: 1 Reset counter: 40 Mileage: 239340 km Time Indication: 0 Date: 2018.04.25 Time: 01:30:42 Freeze Frame: RPM: 224 /min Torque: 0.0 Nm Speed: 0.0 km/h Time: 0.00 s Angle: 0.0 ° Bin. Bits: 00000000 Bin. Bits: 00000001 VCDS result 22-06-19.txt Log-KV56OFX.txt
