Anti shudder valve fuse ?
Nick John
Hi ,
hoping some one can point me in the right direction
Anti shudder valve failed.... Full of oil  so replaced ...  codes were "motor for in take flap(v157) open or short to ground P3101 & Solenoid valve boost pressure N75 Short or open to ground
can any one help with the fuse location ,i have checked all the fuses by the side of the dash and under the dash  all OK
are there any more hidden or which fuse is supposed to run it ?
cheers
Nick
Not sure you are looking for a fuse here. Short or open to ground would suggest an incomplete circuit ot at least an out of range voltage being recognised. Check all loom connectors - dry joints need cleaning and protecting. Sensor connections can degrade over time.
