BenMichaelB1990 Posted July 1, 2019 Posted July 1, 2019 Hi all 馃馃徏 new to group and unfortunately it鈥檚 help/advise I鈥檓 in need of.聽 I have an Audi A4 B8 with a central locking problem.聽 The key is a smart key that slots into the dash.聽 Once in a blue moon the remote will operate the central locking after sync in the ignition.聽 Replaced the fob battery and I鈥檝e replaced the ignition reader/slot in dash as it did use to struggle releasing the key.聽 Still the same though.聽 I鈥檝e had vcds scan and it didn鈥檛 give me any errors. The fob has been tested and it鈥檚 giving out a strong signal.聽 Any of you chaps came across an error like this before If so is there a fix? Or is it simply main dealer only fix?聽 Thanks in advance guys
CCRS Posted September 14, 2019 Posted September 14, 2019 I coul be wrong but the fault on my B8 which would randomly deadlock 1, 2, 3 or all doors at once making it impossible to get in.聽 Turned out that rear door actuators were faulty and these were interfering with the front door locks.聽 Replaced both rear actuators.. Solved it.聽
