Gmt Posted July 4, 2019 Share Posted July 4, 2019 Hi this my first post so here goes ,i have a Audi A4 avant [2010] i have had it for 3 years with no trouble but the alarm has started to go of when the car is parked ,it seams to be when the car is parked in the sun , i took it to a local garage to have the code read and it came up with 01403 glass break sensor rear ,has anyone had a similar problem and if so where is the sensor in the car and can it be replaced or turned off many thanks graham Quote Link to comment Share on other sites More sharing options...
Ajackson Posted July 9, 2019 Share Posted July 9, 2019 Hi The glass brake sensor is a very thin copper track which runs round the tailgate window there are two terminals at the bottom of the window one of them has probably corroded off so just take the other off strip back the wire and join together. This will fix the alarm fault 🙂 Quote Link to comment Share on other sites More sharing options...
Gmt Posted July 11, 2019 Author Share Posted July 11, 2019 Hi i found the 2 wires bottom of the tailgate window cut them and joined the wires together and i thought i had fixed the problem until the next evening then the alarm went off again , it seems to go off at about 7pm when the back of the car is in full sun , anything else i can try many thanks graham Quote Link to comment Share on other sites More sharing options...
Chad Posted August 10, 2020 Share Posted August 10, 2020 Hi, I’ve the same problem! More so when it rains or it’s frosty! Did you manage to resolve the issue as it’s driving me mad! Quote Link to comment Share on other sites More sharing options...
