piperdog Posted July 17, 2019 Share Posted July 17, 2019 hello, ive a 2.7tdi/ 2006 and the car set up button isnt working on the mmi and all the rest are, took it apart and its the circuit board, when i get another one is it just plug and play or do i have to get it programed or such like, thanks Quote Link to comment Share on other sites More sharing options...
Bill Owen Posted July 17, 2019 Share Posted July 17, 2019 Hi mate, I think if you get like for like i.e same part number it should just be plug and play as it was for my radio but, i could be wrong........ best of luck. Quote Link to comment Share on other sites More sharing options...
QuattroMark Posted July 18, 2019 Share Posted July 18, 2019 If you are just replacing the circuit board - then it is just plug and play - just make sure you get the right one.....there are loads on eBay...I know this as I have just done this with mine! If you were replacing the MMI module ( behind the screen) then you would need to recode - or at least have someway of checking (VCDS etc) if the new module is option coded correctly for your vehicle. Quote Link to comment Share on other sites More sharing options...
piperdog Posted July 18, 2019 Author Share Posted July 18, 2019 thanks, bought a used one and all the numbers are the same, just got to wait for it to arrive Quote Link to comment Share on other sites More sharing options...
niedzial1983 Posted July 20, 2019 Share Posted July 20, 2019 If you are replacing mmi panel or the borad only ... no codding required. Just plug and play. But it might be worth taking the current one apart and check of there isnt any spilages that happened , its quite comon. The board is multilayer so trying to fix it would be near imposible Quote Link to comment Share on other sites More sharing options...
