Hi, I'm new to this forum.
I have an audi a4 b9 avant 2.0tdi s line.
I have had a brake servo restricted please return to workshop message appear on dashboard along with start stop not working please return to workshop. This has been intermittent over last week. When the messages appear the brakes feel funny. I don't think it is an actual brake servo fault as I have done the brake pump test. Possible sensor issue? Bit strange for a car less than 2 year old with low miles.
Any ideas anyone?
  • 8 months later...
Hi Steve,
just had the same message appear on display screen. Did you manage to get this resolved?
Thanks
I believe the problem is caused by the brake servo pressure sensor.
Steve
This has just happened for us.
Cost of fix  ?
Is a DIY possibility ?
Regards
CGP
Cost of fix  ?
Regards
CGP
Had a look online but not exactly sure on cost I'm afraid.
Steve
5 hours ago, Richie69 said:
Thanks Steve
You're welcome, please keep us posted on how you get on 👍
Steve
Well, I looked for a blown fuse or a lead off - no luck
Disconnected the battery for a hard reset - no luck
The car had been stood for 4 weeks, was OK before.
Took it for a drive to see if the error would disappear - no luck
Time to let Audi have a look
Please keep us posted. Sorry what you tried didnt work.
Steve
Hi Guys
Managed to get an appointment with Audi, quite difficult with the ongoing pandemic, vehicle tech informed that it was the pressure sensor at fault, so had it replaced with now no issues whatsoever. The cost £200 for parts and labour
4 hours ago, Richie69 said:
Hi Guys
Thanks for the update, glad you got it sorted 👍
Steve
Hi everyone
I have Audi A4 2017 and my car was also parked up for 5 weeks.
I discovered exactly the same fault - restricted break and break pedal feels restricted.
must be a fault with these vehicles when parked up for a long time  !
rather frustrating ...
oksana
4 hours ago, Oksana said:
Hi everyone
oksana
Yep looks to becoming a common fault
Hi I have an Audi A4 TFSI 2017
Exactly the same issue after car sat up for a month or so...Break servo restricted....Gurrr...
Breaks feel a bit clicky and so a call to Audi Monday morning....Im guessing a warranty does not cover it??
Should be covered under warranty 👍
We got ours done for free - I guess its a common thing, done under warranty.
CGP
Dear CGP,
Just out of interest did they say it was a computer or mechanical fault?
Hi All,
New to the site as I was searching for help regarding a warning on my display regarding the brakes and to take it to a service centre.
I plugged my diagnostic tool in and its stating the brake boost sensor fault., vehicle had been off the road for bodywork repairs for weeks prior to this.
Does anybody perhaps have the AUDI part number off an invoice they have.
Thanks in advance for any help.
Follow up to the brake servo warning....
i finally brought it to Audi here in Lyon who said it’s actually a sensor fault and will cost €250 😱
unfortunately my car turned 3 in April and it’s no longer under warranty. 😢 the fault started just before April but all garages were closed..... no way to prove it....
There's should still be some discount due to the fact the car is just out of warranty. You'll have to argue with them unfortunately.
Steve
I'll try but I can just imagine as nice as they are that it will be a case of "Its too late....."
You'll be surprised, and if they're reluctant fight them on it. A part like that shouldn't go either in or just out of warranty. Plus as you can see there's now a few documented cases which you and Audi are both aware of.
I have exactly the same error messages on my 2016 A4 2.0 TD Avant, after the car has been parked in my drive since March. There is a clear pattern here. Will be calling the dealership on Monday, and will post the outcome of my negotiations.
Please keep us posted on how you get on 👍
Hi, everyone... I've had the same problem on our 2017 Q7... parked up for most of lock down and drove it for the first time in a while yesterday and the brake servo and start/stop error appeared... Seems to be a theme here across most models...
