sorin s Posted 22 hours ago Posted 22 hours ago thank you KH904, is it the one advised a few messages up? is it the MAP Brake booster pressure sensor?
ian.f Posted 22 hours ago Posted 22 hours ago 1 hour ago, sorin s said: Hi all, So glad I discovered this forum. 6 weeks ago, while reversing my 2016 A6 S line, my dashboard started to light like a Christmas tree, showing the following errors/faults: - stabilisation control (ESC/ABS): fault!, see owners manual - hold assist: unavailable - main beam assist: system fault - tire pressure: system fault! - parking brake! - Audi adaptive light: system fault! - brake servo restricted. You can continue driving. Please contact workshop. Since then, I probably did a further 500 miles and the car drives as normal...or at least I didn't feel anything suspicious with it; lights work ok, it brakes ok, steering wheel is ok, parking brake holds ok. Have any of you experienced similar? Do you have any advice? Thank you. I second, DO NOT DRIVE ANOTHER MILE! Yes, buy the sensor that’s listed in this thread and change it before you drive it again. I didn’t, and it cost me a fortune to replace & repair the subsequent damage.
kh904 Posted 21 hours ago Posted 21 hours ago 1 hour ago, sorin s said: thank you KH904, is it the one advised a few messages up? is it the MAP Brake booster pressure sensor? It's the brake booster pressure sensor
sorin s Posted 7 hours ago Posted 7 hours ago Thank you both for the valuable advice. Just ordered one from Amazon; will share my feedback after I fit it.
P3N Posted 3 hours ago Posted 3 hours ago Good move Sorin. i had the same message, drove 19 miles all the while the message only stated “ contact garage”. But my car totally failed. It cost me nearly £4k. I hadn’t found this forum 😩 Don’t move another inch until you have fitted the new part. I now carry a spare in the car in case it goes again.
