forceseven Posted August 6, 2019 Share Posted August 6, 2019 I have a left brake light warning light on the dash, however the brake lights are all working? How do I reset the warning light? Quote Link to comment Share on other sites More sharing options...
Magnet Posted August 6, 2019 Share Posted August 6, 2019 Hello Nigel, I would have thought the light should reset itself, but I could be wrong. You say the brake lights are all working, but have you double checked the intensity of each side to ensure they are exactly the same? High level light has uniform illumination? Not unheard of that there might be two bulbs per side, or there could be a high contact resistance at the bulb holders, or within the bulb/s. Worth a double check, since this warning does not come on without reason. Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
forceseven Posted August 6, 2019 Author Share Posted August 6, 2019 Thanks Magnet, Im going to remove rear light units and check lamps and contacts for issues. Will report back. Quote Link to comment Share on other sites More sharing options...
forceseven Posted August 6, 2019 Author Share Posted August 6, 2019 Sorted the problem , one of the two LH brake lights was faulty, replacement fitted, warning light off. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
Magnet Posted August 6, 2019 Share Posted August 6, 2019 Thanks for letting us know Nigel. Glad it is sorted. It is a bit of a catch-you-out with two bulbs per side. Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
