Hi gang,
randomly had the EML pop up on the Audi A3 the other day,
I did a quick scan with a generic OBD scanner and the carista tool and brought up the error P0672.
No other error faults.
As I read up is it as simple as the Glowplug needs replacing, car runs as it should, no loss of power, oil issues etc.
I did run VCDS, only bought up 2 faults, one I think could be due to my lighting and the glow plug issue.
Whats the best glowplugs to buy as i prob change the lot.
I cant afford OEM as a full set it £155, ECP with discount are doing BOSCH for £55 or NGK for £81
Code:
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 AS HW: 04L 907 309 A
Component: R4 2,0L EDC H22 8133
Revision: 81H22---
Coding: 02190012032501082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TDI01104L906021AS 002009
ROD: EV_ECM20TDI01104L906021AS_002.rod
VCID: 76E43D9AC95C7DFFB3-8022
1 Fault Found
4985 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 00 [237] - Electrical Fault
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 105176 km
Date: 2019.08.20
Time: 11:56:16
Engine speed: 875.00 /min
Normed load value: 36.5 %
Vehicle speed: 0 km/h
Coolant temperature: 24 °C
Intake air temperature: 23 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.640 V
TNF 167462: Write only channel
Readiness: 1 1 0 0 0
Code:
Address 19: CAN Gateway (J533) Labels:. 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1204
Revision: -------- Serial number: 0003366166
Coding: 030100041F0876005B000248080B00000001010000000000000000000000
ASAM Dataset: EV_GatewLera 011020
ROD: N/A
VCID: 71EE0E86A0325AC766-8024
Subsystem 2 - Part No SW: 8U0 951 528 HW: 8U0 951 528
Component: E221 - MFL H02 0014
Serial number: 10 04 2015 B0034639
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185703001504091069
No ASAM data for: "EV_GatewLera" (AU37)
1 Fault Found
8531970 - ROD - Unknown Error Code
- 00 [008]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 80
Mileage: 105239 km
Date: 2019.08.21
Time: 22:32:53
  • 5 months later...
Hi mate,
Did you have any luck with replacing glow plugs.
Got the exact same issue, scanned with code reader and got glow plug cylinder 2 error.
Andy
Hello Andrew,
OP posted on the 23 Aug. and simply hasn’t return to the forum since!
