Aircon Not Working - AC Pressure/Temp Sensor only?
TechAdvice
This is the report produced from VCDS below - Is this the high pressure switch?
If so, can i simply remove just the grill to change it?
Also can anyone tell me which one I need without removing the existing?
Thanks
00256 - A/C Pressure/Temperature Sensor (G395)
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 132479 km
                    Time Indication: 0
                    Date: 2019.08.16
                    Time: 18:00:12
  009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                00797 - Sunlight Photo Sensor (G107)
                Fault Status: 00101001
                    Fault Priority: 3
                    Fault Frequency: 176
                    Reset counter: 219
                    Mileage: 130752 km
                    Time Indication: 0
                    Date: 2019.05.02
                    Time: 14:05:27
