TechAdvice Posted August 31, 2019 Posted August 31, 2019 This is the report produced from VCDS below - Is this the high pressure switch? If so, can i simply remove just the grill to change it? Also can anyone tell me which one I need without removing the existing? Thanks 00256 - A/C Pressure/Temperature Sensor (G395) 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 195 Mileage: 132479 km Time Indication: 0 Date: 2019.08.16 Time: 18:00:12 009 - Open or Short to Ground - Intermittent Freeze Frame: 00797 - Sunlight Photo Sensor (G107) Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 176 Reset counter: 219 Mileage: 130752 km Time Indication: 0 Date: 2019.05.02 Time: 14:05:27
