My TT is showing several error message when driving which has gradually become worse over time.
Initially all flashing up as errors at once was the ABS braking, Headlight range, Tyre Pressure. Sometimes the spoiler would also come up with a fault along with hill assist and rear parking sensors all at once.
A local garage believe that it is one rear ABS sensor causing the problem and still believe it was fine to drive until replaced. However since then along with the errors above, the speedometer has stopped working and remains at 0 when driving, power steering stopped working, the parking break will not apply and there is an error message saying the breaks are faulty.
Has anyone else had a similar problem, or have any idea what the issue could be? I’m not sure if I need to take it to an Audi garage instead of a local one?
