Richard Bayle Posted October 4, 2019 Share Posted October 4, 2019 Keep getting this message "Low Voltage". It disappears and everything seems to be operating normally. can't find it in the manual. Any ideas? Quote Link to comment Share on other sites More sharing options...
Magnet Posted October 5, 2019 Share Posted October 5, 2019 Hello Richard, I suppose the first obvious thing to check would be the battery efficiency, followed by the charging rate if the battery proves serviceable. Perhaps you could let us know how you get on. Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Richard Bayle Posted October 5, 2019 Author Share Posted October 5, 2019 Actually the message is "under voltage" Goes away immediately I start the car and is intermittent. i.e. Doesn't happen every time I start the car. Battery is fine, charging is OK so bemused Quote Link to comment Share on other sites More sharing options...
Magnet Posted October 5, 2019 Share Posted October 5, 2019 Hello Richard, ’....... battery is fine’. Have you actually had it checked and confirmed as so? Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Richard Bayle Posted October 5, 2019 Author Share Posted October 5, 2019 Yep Quote Link to comment Share on other sites More sharing options...
Magnet Posted October 6, 2019 Share Posted October 6, 2019 OK, short answer = yep! Next question:- what parameters of the battery were checked? Included cold cranking current values?? It’s still - kind regards to you in Guadeloupe from Gareth in Wales. Quote Link to comment Share on other sites More sharing options...
Richard Bayle Posted October 6, 2019 Author Share Posted October 6, 2019 Cold Cranking?? It never gets below 24 C here 😂 garage hardly dips below 28. I know what you mean and yes, the Audi dealer here has done all the checks and is as confused as I am. They have asked Audi and are waiting a response but think it's an electrical blip. Hope the weather no too wet for you in Wales, I hear hurricane Lorenzo is giving you a last gasp kick Quote Link to comment Share on other sites More sharing options...
Magnet Posted October 6, 2019 Share Posted October 6, 2019 Hello Richard, Checking the Cold Cranking Current (CCA) efficiency is a way of assessing the efficiency of the battery under load, and many vehicles are now fitted with a battery monitoring module which continuously monitors its efficiency and it has set parameters which must be satisfied otherwise warnings are given, even though the battery may now show any symptoms. It could be said, yours is too old to be fitted with one. I could narrate a very recent example of this type of ‘failure’ on a so called prestige vehicle, but it may bore. If it were mine I would be looking to substitute the battery for another, after I had checked all battery linked cables and associated main earths. Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
niedzial1983 Posted October 7, 2019 Share Posted October 7, 2019 Where is the message ? In the dash between the speedos or mmi screen? Quote Link to comment Share on other sites More sharing options...
Richard Bayle Posted October 7, 2019 Author Share Posted October 7, 2019 MMI Screen. Hasn't happened for a couple of days so I think "blip" might be the answer Quote Link to comment Share on other sites More sharing options...
