Sara Posted October 10, 2019 Posted October 10, 2019 Evening thought I’d try this before succumbing and booking diagnostics at Audi have a prob with my MMI - first it would come on and then radio would go on and off - everything else fine - then crackly speakers - now it comes on and shows everything as not installed radio, sat nav, media etc my reverse camera is also off and also the reversing beep noise is no more tried the reset but didn’t do anything - any ideas guys thanks
niedzial1983 Posted October 14, 2019 Posted October 14, 2019 You need to get a vcds scan and check the fault codes. Most garages should be able to do that. I vote for a problem with MOST fibre optic loop . Most likley caused by water damage
