HonestTony Posted October 30, 2019 Posted October 30, 2019 Last week my 2.0 TDI died at 65mph on the motorway!!! Had it towed home and put the VCDS on it (report below) - all I have done is replace the Crank Sensor G28 and the oil pressure sensor but it still wont start.so I would welcome any suggestions before I resort to the scrap man! Tuesday,22,October,2019,09:15:06:53651 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.1.0.0 Data version: 20170106 DS267.0 www.Ross-Tech.com VIN: WAUZZZ4F06N108210 License Plate: Chassis Type: 4F (4F0) Scan: 01 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61 62 72 76 VIN: WAUZZZ4F06N108210 Mileage: 276180km-171610miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: Malfunction 1010 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 1010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: Malfunction 1010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Sporadic communication error 1000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 1010 72-Door, Rear Right -- Status: Sporadic communication error 1000 76-Park Assist -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BLB.clb Part No SW: 03G 906 016 HS HW: 028 101 255 7 Component: R4 2,0L EDC G000SG 9673 Revision: --H01--- Serial number: Coding: 0000072 Shop #: WSC 00134 210 91052 VCID: 7BF591C93A34F3999A-802E 3 Faults Found: 005697 - Please check DTC Memory of A/C Controller P1641 - 000 - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 255 Mileage: 259580 km Time Indication: 0 Date: 2019.01.01 Time: 13:58:15 Freeze Frame: RPM: 945 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 13.00 V Bin. Bits: 00101000 Temperature: 8.1°C (no units): 16.0 006464 - Powertrain Databus P1940 - 000 - Missing Message from Control Module for Battery Monitoring - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 276037 km Time Indication: 0 Date: 2019.10.20 Time: 13:57:18 Freeze Frame: RPM: 1008 /min Speed: 3.0 km/h Load: 0.0 % Voltage: 13.76 V Bin. Bits: 00101100 Bin. Bits: 00000000 (no units): 65.0 000802 - Engine Speed Sensor (G28) P0322 - 000 - No Signal - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 276179 km Time Indication: 0 Date: 2019.10.22 Time: 04:57:55 Freeze Frame: RPM: 1764 /min Speed: 89.0 km/h Load: 0.0 % Voltage: 13.68 V Bin. Bits: 00101000 Idle Stabilization: 0.0°KW RPM: 882 /min Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 K HW: 4F0 614 517 K Component: ESP 8.0 front H04 0090 Revision: 00000000 Serial number: 00000000000000 Coding: 0020855 Shop #: WSC 02325 785 00200 VCID: 2C5762958FDAA42143-8078 2 Faults Found: 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 182 Mileage: 276037 km Time Indication: 0 Date: 2019.10.20 Time: 13:57:18 Freeze Frame: Hex Value: 0x0300 Hex Value: 0x4082 Hex Value: 0x0028 Hex Value: 0x01AB Hex Value: 0x00FF 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 182 Mileage: 276179 km Time Indication: 0 Date: 2019.10.22 Time: 04:57:55 Freeze Frame: Hex Value: 0x5800 Hex Value: 0x4006 Hex Value: 0x0027 Hex Value: 0x01AC Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 EL Revision: 31050601 Serial number: 10604000292585 Coding: 0000145 Shop #: WSC 00134 210 91052 VCID: 63C5C9A9A2842B59B2-8036 Subsystem 1 - Part No: 4F0 910 131 D Component: FBSAUDIC6 EZS H45 0080 Subsystem 2 - Part No: 4F0 910 220 D Component: FBSAUDIC6 IDG H39 0040 1 Fault Found: 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 21 Reset counter: 181 Mileage: 276036 km Time Indication: 0 ------------------------------------------------------------------------------- Address 07: Control Head Labels: Redir Fail! Part No SW: 4F0 910 769 A HW: 4F0 035 769 A Component: MMI Cockpit H35 0010 Revision: C51100DE Serial number: AUZ6Z3EAX22913 Coding: 0500122 Shop #: WSC 02325 785 00200 VCID: 2B5561898AD4A3194A-807E Subsystem 1 - Part No: 4F0 910 609 E Component: Bedienteil MMIC6H03 0050 Subsystem 2 - Serial number: 00000000262158 Subsystem 3 - Serial number: 0124.10.050000000100010971ÿ Subsystem 4 - Serial number: 010971ÿ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.clb Part No SW: 4F0 910 043 HW: 4F2 820 043 J Component: KLIMABETAETIGUNGH12 0160 Revision: 00000027 Serial number: 00000030068647 Coding: 0001300 Shop #: WSC 02325 785 00200 VCID: 5BB5F1499AF41399FA-800E 2 Faults Found: 00256 - A/C Pressure/Temperature Sensor (G395) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 75 Mileage: 261396 km Time Indication: 0 Date: 2019.02.17 Time: 12:04:10 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 181 Mileage: 276036 km Time Indication: 0 Date: 2019.10.20 Time: 13:56:16 Freeze Frame: ON ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 D HW: 4F0 907 279 Component: ILM Fahrer H15 0190 Revision: 00000000 Serial number: 4F0907279 Coding: 0010101 Shop #: WSC 02335 785 00200 VCID: 2A5B648D852EBA11B1-807E Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB Component: Wischer AudiC6 H04 0150 Coding: 00062736 Shop #: WSC 02335 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0050 Coding: 00141886 Shop #: WSC 02335 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: Redir Fail! Part No SW: 4F0 910 769 A HW: 4F0 035 769 A Component: MMI Cockpit H35 0010 Revision: C51100DE Serial number: AUZ6Z3EAX22913 Coding: 0500122 Shop #: WSC 02325 785 00200 VCID: 2B5561898AD4A3194A-807E 1 Fault Found: 00468 - CD-ROM Drive (R92) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 5 Fault Frequency: 5 Reset counter: 178 Mileage: 276037 km Time Indication: 0 Date: 2019.10.20 Time: 14:42:06 Freeze Frame: Bin. Bits: 01000 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.clb Part No SW: 4F0 910 655 E HW: 4F0 959 655 B Component: 4F AIRBAG AUDI8RH29 0260 Revision: 07H29000 Serial number: 0037LD0AYB3G Coding: 0013382 Shop #: WSC 02325 785 00200 VCID: 29599B818028B109B8-807C Subsystem 1 - Serial number: 6332CSME0C563126$ Subsystem 2 - Serial number: 6342CSME0C56312B2 Subsystem 3 - Serial number: 6352QSME0636104B8 Subsystem 4 - Serial number: 6362QSME06302D1FI Subsystem 5 - Serial number: 63734SME06081F7D8 Subsystem 6 - Serial number: 63834SME060C1651X No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H07 0230 Revision: 00H07000 Serial number: 90026053030136 Coding: 0102042 Shop #: WSC 02323 785 00200 VCID: 66C3D0BD51B65E7155-8032 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 900 A HW: 4F0 920 950 L Component: KOMBIINSTR. M73 H11 0630 Revision: 00100000 Serial number: 4RA17A1C5 Coding: 2308443 Shop #: WSC 14557 067 57207 VCID: 1E33B85DC96646B1DD-804A 1 Fault Found: 00473 - Control Module for Elect. Park/Hand Brake (J540) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 172 Mileage: 275797 km Time Indication: 0 Date: 2019.10.12 Time: 17:09:08 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.clb Part No SW: 4F0 910 468 A HW: 4F0 907 468 D Component: Gateway H11 0070 Revision: 11 Serial number: 1300805B098078 Coding: ECEE53C41B0104 Shop #: WSC 02334 785 00200 VCID: 275D9DB9963C8779AE-8072 8 Faults Found: 00470 - Company Comfort Databus in Single Wire 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 6 Reset counter: 178 Mileage: 274876 km Time Indication: 0 Date: 2019.09.28 Time: 09:19:44 00473 - Control Module for Elect. Park/Hand Brake (J540) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 172 Mileage: 275797 km Time Indication: 0 Date: 2019.10.12 Time: 17:09:07 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 181 Mileage: 276036 km Time Indication: 0 Date: 2019.10.20 Time: 12:10:36 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 178 Mileage: 276037 km Time Indication: 0 Date: 2019.10.20 Time: 13:58:29 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 178 Mileage: 276037 km Time Indication: 0 Date: 2019.10.20 Time: 13:58:29 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 178 Mileage: 276037 km Time Indication: 0 Date: 2019.10.20 Time: 13:58:29 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 3 Reset counter: 178 Mileage: 276037 km Time Indication: 0 Date: 2019.10.20 Time: 13:58:29 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 1 Reset counter: 178 Mileage: 276037 km Time Indication: 0 Date: 2019.10.20 Time: 13:58:31 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 793 E Component: TSG FA H12 0080 Revision: 00000000 Serial number: Coding: 0003706 Shop #: WSC 02327 785 00200 VCID: 2C5762958FDAA42143-8078 1 Fault Found: 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 157 Reset counter: 181 Mileage: 276036 km Time Indication: 0 Date: 2019.10.20 Time: 12:10:37 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 G HW: 4F0 907 289 G Component: Komfortgeraet H22 0170 Revision: 01700022 Serial number: 01008527360000 Coding: 0271099 Shop #: WSC 02335 785 00200 VCID: 2E53689DB9C6D6316D-807A Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 Subsystem 2 - Part No: 4F0 910 177 Component: Innenraumueberw.H01 0020 2 Faults Found: 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 19 Reset counter: 181 Mileage: 276036 km Time Indication: 0 Date: 2019.10.20 Time: 12:10:40 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 178 Mileage: 276037 km Time Indication: 0 Date: 2019.10.20 Time: 13:58:34 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4F0-910-223-AS.lbl Part No SW: 4F0 910 223 C HW: 4F0 035 223 Component: Amp.-ASK H10 0320 Revision: 31S00001 Serial number: 01011050175156 Coding: 0000103 Shop #: WSC 02335 785 00200 VCID: 1E33B85DC96646B1DD-804A No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 A Component: ILM Beifahrer H10 0080 Revision: Serial number: 00000000154672 Coding: 0001114 Shop #: WSC 02323 785 00200 VCID: 5EB3F85D89E606B19D-800A 3 Faults Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 178 Mileage: 262136 km Time Indication: 0 Date: 2019.10.20 Time: 13:58:00 Freeze Frame: Voltage: 12.700 V Not Recogn. 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 178 Mileage: 262136 km Time Indication: 0 Date: 2019.10.20 Time: 13:58:00 Freeze Frame: Voltage: 12.700 V Temperature: 12.0°C 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 178 Mileage: 262136 km Time Indication: 0 Date: 2019.10.20 Time: 13:58:00 Freeze Frame: Voltage: 12.700 V Temperature: 20.0°C ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 792 E Component: TSG BF H12 0080 Revision: 00-00000 Coding: 0003706 Shop #: WSC 02327 785 00200 VCID: 2C5762958FDAA42143-8078 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.clb Part No SW: 4F0 910 801 HW: 4F0 907 801 Component: EPB C63C0030 H03 0030 Revision: C63C0030 Coding: 0000111 Shop #: WSC 02334 785 00200 VCID: 5DB1FF5184E01DA984-8008 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: Redir Fail! Part No SW: 4F0 910 769 A HW: 4F0 035 769 A Component: MMI Cockpit H35 0010 Revision: C51100DE Serial number: AUZ6Z3EAX22913 Coding: 0500122 Shop #: WSC 02325 785 00200 VCID: 2B5561898AD4A3194A-807E No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: J0644 BEM H12 0590 Revision: 00000000 Serial number: 00000000149854 Shop #: WSC 00182 210 12587 VCID: 234589A9E2046B59F2-8076 Subsystem 1 - Part No: 4F0 915 105 C Component: von VA0 1510310767 Coding: 344630393135313035432056413031353130333130373637 Shop #: WSC 00000 384 00290 1 Fault Found: 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 178 Mileage: 276037 km Time Indication: 0 Date: 2019.10.20 Time: 13:58:28 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 E HW: 4F0 959 795 E Component: TSG HL H21 0050 Coding: 0003114 Shop #: WSC 02327 785 00200 VCID: 2E53689DB9C6D6316D-807A 2 Faults Found: 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 25 Reset counter: 181 Mileage: 276036 km Time Indication: 0 Date: 2019.10.20 Time: 12:10:37 01336 - Company Data Bus for Comfort System 014 - Defective - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 25 Reset counter: 181 Mileage: 276036 km Time Indication: 0 Date: 2019.10.20 Time: 12:10:37 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 E HW: 4F0 959 794 E Component: TSG HR H21 0050 Coding: 0003114 Shop #: WSC 02327 785 00200 VCID: 2E53689DB9C6D6316D-807A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4F0 910 283 B HW: 4F0 919 283 B Component: Parkhilfe 4-Kan H09 0030 Revision: 00H09000 Serial number: 11720529708189 Coding: 0000016 Shop #: WSC 131071 1023 2097151 VCID: 234589A9E2046B59F2-8076 1 Fault Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 3 Reset counter: 178 Mileage: 276037 km Time Indication: 0 Date: 2019.10.20 Time: 13:58:28 End-------------------------(Elapsed Time: 02:30)--------------------------
