AudiA5CoupeScotland Posted November 2, 2019 Posted November 2, 2019 Hi I am hoping someone can help as I have an issue with a door open light on the dash. The lights can been seen still on from under and side of the door also. The door cannot lock with the fob but I can lock it with the key. Last month I had the common problem of the door not opening the drivers side and so replaced the drivers door actuator - this solved the problem and worked well for 4 weeks! Now the issue above - some seem to say its a microswitch for locking - am i unlucky and the new microswitch on my actuator has failed or is the switch somewhere else? Or another problem. Audi 2008 Coupe (57 Model) - 3.0 TDI Quattro Any help appreciated!
