Basically  my audi a3 2010 black edition mirror not working when I indicator right (drivers side) the light on the mirror not work also the heated mirror not heating and there is no movement in the mirror either but the passenger side mirror is fully functional just wonder what fuses I need to check cant find it in the manual would both mirror be on the same fuse? Maybe I have a faulty connection?if anyone could help would be great thanks
  • 5 months later...
If I were you the first thing I'd do is get the glass out and using a multimeter or 12v test lamp see if you have power at the connections, if it is the wiring then it connects through the door panel.
