jasonrob39 Posted May 20, 2011 Posted May 20, 2011 hi all, just purchased an a4 estate sline 2006,i noticed the rear windscreen washer is not getting water to it,the pump work but no water any suggestion,oh what a great car the a4 is!
A4geezer Posted May 30, 2011 Posted May 30, 2011 Hi try this, I had the same problem; remove the plastic cover from the wiper arm (the part that connects to the main body by the rear windscreen) the plastic cover will pull off with gently force; it has two snake eyes where the washer jet are. Under the cover is a small housing, unscrew this and clean the jets, a sewing needle should do it, replace in the reverse order and align the snake eyes with the needle. Good luck hope this works hi all, just purchased an a4 estate sline 2006,i noticed the rear windscreen washer is not getting water to it,the pump work but no water any suggestion,oh what a great car the a4 is!
