MYosh Posted December 11, 2019 Posted December 11, 2019 I have a 2015 A3 Quattro. I have no heat coming from the vents at any hot setting. The blower seems to be working fine but get no heat control or hot air in the vents. The passenger side has a little bit of heat at the highest setting but the driver side is cold. How do I troubleshoot this issue. thks in advance.
Fatbloke Posted December 29, 2019 Posted December 29, 2019 Some vehicles have a perforated bag of beads in the coolant expansion bottle to boost the coolant. These have been known to burst and the beads clog the heater matrix. Check to see if yours has a bag and if its intact. More than likely it's an airlock somewhere and the system needs bled, thermostat issue or water pump issue.
Magnet Posted December 29, 2019 Posted December 29, 2019 Hello David, Never too old to learn as they say......’Perforated bag of beads in the coolant expansion tank to boost the coolant’. Could you enlighten us on the makes of these vehicles which come with these bags as original equipment? Also, in what way are they supposed to ‘boost’ the coolant. Hello Michael, David mentions possible thermostat or water pump causes. Could you let us know if the car gets up to Normal (90) on the gauge after a couple of miles or not? Kind regards, Gareth.
Fatbloke Posted December 29, 2019 Posted December 29, 2019 Some of the A3's have them seemingly. Probably other models too. Other VAG's use them also. Its silica or something in them to boost the properties of the coolant as far as I understand. Some people remove them to prevent them bursting.
Magnet Posted December 29, 2019 Posted December 29, 2019 Many thanks, Strange they should submerge such things in the coolant reservoir as original equipment. I wonder why they don’t simply add whatever the chemical is ( doubt silica) to the coolant fluid? Live and learn as they say.
Hoddybobby Posted January 30, 2022 Posted January 30, 2022 No loss of water no over heating can't see the bag but it's full of water drives mint not any issues just not blowing any heat. Did anyone fix this. Snapchat-798113718.mp4
Jonboy walton Posted October 16, 2023 Posted October 16, 2023 Iv got Audi A3 tdi 2.0l 2013 and the problem I’m having is I let it get up to temp (90c) turn the heat on hot and it’s hot then a few seconds later goes cool. Then turn it off for a few minutes then the same happens.
Zcuzz Posted December 14, 2023 Posted December 14, 2023 On 10/16/2023 at 1:06 PM, Jonboy walton said: Iv got Audi A3 tdi 2.0l 2013 and the problem I’m having is I let it get up to temp (90c) turn the heat on hot and it’s hot then a few seconds later goes cool. Then turn it off for a few minutes then the same happens. Did you ever get this issue fixed?
Fatbloke Posted December 30, 2023 Posted December 30, 2023 A wee bit further info. I had an issue on my Skoda VRS where the fans etc were working but no heat on passenger side vents. Turned out to be a thermistor in the vent pipe was reading high temp so hot air flaps didn't open as it thought it was already too warm. Replaced thermistor and all working again. Info just in case someone else has a similar issue. 1
Bobbykane Posted May 1, 2024 Posted May 1, 2024 I have reached out to Snapchat for support, but it seems like it is useless. A few days ago I changed my Snapchat password (I thought I was changing a password to another account) and then deactivated it. I tried to reset my password via phone/email, but it seems that it does not work, then a friend of mine referred me to a great guy that was able to recover any hacked/ deactivated or deleted account, message Yt7crackersz@ gmail .com & I.G @ Yt7crackersz To get back your compromised account, he is the only professional to resolve my account issue within some couple min..
