I have 2003 A4 AVANT 1.9 , a friend has given me 18" set of alloys , will they easy fit and replace my 16s with no issues . Bolt pattern is same . Thanks
Hello Allan,
If you are considering fitting larger wheels (two sizes up) then you have to ensure the final outside diameter of the new wheels and tyres is the same as your current wheels and tyres. i.e. what you gain in wheel diameter you have to lose in tyre profile (depth). This loss of depth of rubber will obviously affect the ride quality.
Gareth,
Gareth , thanks for the help .
