paxterg Posted January 18, 2020 Posted January 18, 2020 How hard is it to change an air filter? Been waiting on my mechanic for a while and thought I might try it myself.
sbt Posted January 19, 2020 Posted January 19, 2020 Extremely easy if you can undo 4 to 6 screws . locate big black box undo the screws surrounding the top remove top remove old filter replace new filter tighten screws job done ten mins max
paxterg Posted January 19, 2020 Author Posted January 19, 2020 Ok, do I need to unplug the air flow sensor?
sbt Posted January 19, 2020 Posted January 19, 2020 Yes you can do it will allow you to lift the lid higher also hoover out the box there will be leaves and dust in there
