various problems
mogsy
Just recently started on my 2010 b8, 2.0 tdi manual transm,ission
gear suggestion stopped, it is turned on.
auto handbrake release stopped,handbrake works fine manually,not hill start assist, car doesn't have this.
left reverse lamp stopped, not the bulb,
engine fans come on when engine switched off, even when cold.but don't run when engine is running
oil level sensor fault
Difficult to tell but apart from oil sensor issue all seemed to start at the same time
Any ideas anyone
VCDS only shows bulb and oil sensor problems
