I have had the 'ACC and Brake Guard unavailable' error since December - it's been into Audi in Edinburgh and Glasgow and although they fitted new ABS sensor - this message has not gone away.
I have seen others posting a full VAGCOM in other posts regarding this issue - I would like to do the same, but do not have access to the kit.
Anyone in Glasgow who has one, or know of someone who does? Are the eBay unbranded ones as good as the branded one?
I just need to check the faults that seem to be mentioned for this fault - door locks and GPS fin.
Thomas
Hello Thomas,
Sorry to hear of your continued issues.
Apologies for being pedantic but you now say ‘they have fitted a new ABS sensor’ (in isolation?) yet your earlier post confirms a new sensor and (in caps) a new hub.
Self diagnosis? OK, it may - just may - lead to you personally gaining some extra knowledge, but the back and front of it is that the car is under warranty, and the seller appears to be very accommodating in trying to sort it out for you.
All very positive, and trying to go down a self diagnosis route could lead to an (understandable?) judgement of ‘you/someone has been fiddling with it’, or indeed they getting the opinion of you being a clever .... so and so, and attitudes might just change.
It is actually the garage I got it off who asked me if I knew of anyone with the new RossTech thing...
Anyway, regardless of the outcome of this I will still be the owner of a VAG car one way or the other, so I have bought the OBDEleven bluetooth connector and now have a full output of codes to pass to the garage...
That said - here they are for the hivemind...anything jumps out, please say!
OBDeleven data log
Date: 2020-01-26 13:22
    VIN: XX
    Car: Audi A6 Allroad
    Year: 2014
    Body type: Avant
    Engine: CGQB 230 kW (313 HP) 3.0 l
    Mileage: 126373 KM
01 Engine Control Module 1
    System description: 3.0BTD EDC17
    Software number: 4G0907589C
    Software version: 0001
    Hardware number: 4G0907589
    Hardware version: H25
    ODX name: EV_ECM30BTD0114G0907589C
    ODX version: 001001
    Long coding: 322A403225760B020000
    Trouble codes:
        No trouble codes found
02 Transmission Control Module
    System description: 0BK 30RTDIRdW
    Software number: 4G0927158L
    Software version: 1003
    Hardware number: 0BK927156AM
    Hardware version: H16
    ODX name: EV_TCMAL551211
    ODX version: 002022
    Long coding: 000001
    Trouble codes:
03 Brakes 1
    System description: ESP PREMIUM
    Software number: 4G0907379M
    Software version: 0450
    Hardware number: 4G0907379M
    Hardware version: H09
    Serial number: --------------
    ODX name: EV_ESPPremiAU57X
    ODX version: 004039
    Long coding: 49A7DF0592E5FBA0FB00
    Trouble codes:
04 Steering Angle Sender
    Trouble codes:
05 Kessy
    System description: BCM2 2.0
    Software number: 4H0907064CN
    Software version: 0433
    Hardware number: 4H0907064CN
    Hardware version: H33
    Long coding: 01B93046000000000000
    Subsystems:
        System description: J764 ELV MLB
        Software number: 4H0905852C
        Software version: 0046
        Hardware version: H40
        Serial number: 2313000106737005
    Trouble codes:
08 Air Conditioning
    System description: KLIMA 4 ZONEN
    Software number: 4G0820043AD
    Software version: 0087
    Hardware number: 4G0820043AD
    Hardware version: H13
    Serial number: 22061300040258
    ODX name: EV_AirCondiComfoUDS
    ODX version: 002040
    Long coding: 3622007825
    Trouble codes:
        U111300 - Function limitation due to received malfunction value
            static
                Date: 2020-01-25 17:23:42
                Mileage: 126373 km
                Priority: 6
                Malfunction frequency counter: 1
                Unlearning counter: 98
                Dynamic environmental data: 02860C31260973261312FC
        B109E13 - A/C compressor first run Open circuit
            static
                Mileage: 126373 km
                Priority: 6
        B126411 - Windshield defogger activation Short circuit to ground
            static
                Mileage: 126373 km
                Priority: 6
        B126412 - Windshield defogger activation Short circuit to B+
            static
                Mileage: 126373 km
                Priority: 6
09 Central Electrics
    System description: BCM1 2.0
    Software number: 4H0907063CE
    Software version: 0130
    Hardware number: 4H0907063E
    Hardware version: H12
    Serial number: 00000001745791
    Long coding: 0200201050B49FE2C98100C000001908CF9D67082F080201000008406100
    Subsystems:
        System description: WWS57X 130618
        Software number: 4G2955119
        Software version: 0080
        Hardware version: H36
        Serial number:         130620152538
        Long coding: 0045F7
        System description: G397_RLFS
        Software number: 8U0955559B
        Software version: 0002
        Hardware version: H06
        Serial number: 21462662
        Long coding: 02006D
        System description: E1 - LDS
        Software number: 4G0941531S
        Software version: 0044
        Hardware version: H07
        Serial number: 28 06 2013  00001337
        System description: AQ_Hum_Sensor
        Software number: 4H0907658
        Software version: 0003
        Hardware version: H03
        Serial number: 7719C4B6000000000001
    Trouble codes:
        01229 - Humidity sensor, A/C system Faulty
            static
                Priority:  3
                Frequency counter:  1
                Driving cycle: 98
                Mileage: 126373 km
                Date: 2020-01-25 17:23:00
10 Parking Assistance 2
    System description: PARKHILFE PLA
    Software number: 4H0919475AB
    Software version: 0060
    Hardware number: 4H0919475E
    Serial number: 56261318003980
    ODX name: EV_EPHVA2CAU57X0000
    ODX version: 002012
    Long coding: B93B0C
    Trouble codes:
13 Adaptive Cruise Control
    System description: ACC3
    Software number: 4G0907561A
    Software version: 0410
    Hardware number: 4G0907561
    Hardware version: H19
    Serial number: 00000000000000
    ODX name: EV_AdaptCruisContrAU57X
    ODX version: 002010
    Long coding: 7F04010202
    Trouble codes:
            Intermittent
                Date: 2020-01-25 17:23:43
                Mileage: 126373 km
                Priority: 6
                Malfunction frequency counter: 2
                Unlearning counter: 138
                Dynamic environmental data: 028D000B02852EDA100EFFFD100FFDE8
15 Airbag
    System description: Airbag10.43
    Software number: 4H0959655C
    Software version: 0040
    Hardware number: 4H0959655C
    Hardware version: H43
    Serial number: 003JG00DVSXE
    ODX name: EV_AirbaAU10BPAAU64X
    ODX version: 001014
    Long coding: 3032343631334E303539554A305234473053
    Trouble codes:
16 Steering Column Electronics
    System description: Lenks.Modul
    Software number: 4H0953568G
    Software version: 0005
    Hardware number: 4H0953568G
    Hardware version: H04
    Serial number: 90372MFR001G3
    Long coding: 0000FD
    Subsystems:
        System description: E221 - MFL
        Software number: 4G0951528E
        Software version: 0010
        Serial number: 22 05 2013  33011847
    Trouble codes:
17 Dash Board
    System description: TDieGb AccNv
    Software number: 4G9920950P
    Software version: 0618
    Hardware number: 4G9920950P
    Hardware version: H80
    Serial number: 6581406135960075
    ODX name: EV_RBD4K
    ODX version: 004048
    Long coding: 338620081F512600010600
    Trouble codes:
19 Gateway
    System description: J533--Gateway
    Software number: 4G0907468AC
    Software version: 0037
    Hardware number: 4G0907468AC
    Serial number: 00000000999979
    ODX name: EV_GatewPkoUDS
    ODX version: 001018
    Long coding: 00CD077D00
    Subsystems:
        System description: J367-BDMHella
        Software number: 8T0915181
        Software version: 8041
        Serial number: 8141390603
    Trouble codes:
        U140600 - Static current too high
            Intermittent
                Date: 2020-01-25 19:30:08
                Mileage: 126373 km
                Priority: 7
                Voltage terminal 30: 12.5 V
                Voltage terminal 15: 0.0 V
                Control module temperature: 15 °C
                System status: LIN_active
                Terminal 15 status: Off
                Terminal 15 status via CAN: Off
                IN ZAS_Kl_X: Off
                Engine running: Off
                IN ESP_Stillstandsflag: no standstill detected
                Datenfeld: 0
        U140B00 - Energy management active
            Intermittent
                Date: 2020-01-25 22:33:19
                Mileage: 126373 km
                Priority: 7
                Voltage terminal 30: 12.4 V
                Control module temperature: 10 °C
                System status: Awake_Timer_active
                IN ZAS_Kl_X: Off
                Engine running: Off
                Datenfeld: 1
28 Climate Control Unit Rear
    System description: KLIMA FOND
    Software number: 4G0919158J
    Hardware number: 4G0919158J
    Serial number: 03071300040346
    ODX name: EV_ClimaContrUnitRearUDS
    ODX version: 002019
    Long coding: 22
    Trouble codes:
        B10D322 - Left rear upper body vent motor Upper limit exceeded
            static
                Date: 2020-01-26 13:18:02
                Mileage: 126373 km
                Priority: 3
                Dynamic environmental data: 02860BAC26097226A62EE92EE92C902710
        B10D422 - Right rear upper body vent motor Upper limit exceeded
            static
                Date: 2020-01-26 13:18:03
                Mileage: 126373 km
                Priority: 3
                Dynamic environmental data: 02860BB126097226A72EDD2EDD2C842710
34 Ride Control System
    System description: LUFE-DAEMPFER
    Software number: 4G0907553F
    Software version: 0782
    Hardware number: 4G0907553F
    Hardware version: H18
    Serial number: �‰ST
    ODX name: EV_AirSuspe
    ODX version: 003024
    Long coding: 008003
    Trouble codes:
3B Sensor Electronics
    System description: SARA 6D
    Software number: 4G0907637K
    Software version: 0056
    Hardware number: 4G0907637F
    Hardware version: H02
    Serial number: EJ1BPA82044ZLP����������
    ODX name: EV_SARA2
    ODX version: 005012
    Trouble codes:
3C Lane Change Assistant
    System description: J769  SWA MasterH04
    Software number: 4G0907566E
    Hardware number: 4G0907566
    Serial number: 6PZ 010 287-04
    Coding: 0011104
    Subsystems:
        System description: J770  SWA Slave H04
        Software number: 4G0907568E
    Trouble codes:
42 Door Electronics Driver Side
    System description: TSG FA
    Software number: 4G8959793H
    Software version: 0507
    Hardware number: 4G8959793F
    Long coding: 011F16005C01628002080013
    Trouble codes:
44 Steering Assistance
    System description: RCEPS
    Software number: 4G0909144L
    Hardware number: 4G0909144G
    Hardware version: H38
    Serial number: 0029630591
    ODX name: EV_RCEPS
    ODX version: 009008
    Long coding: 101101010000
    Trouble codes:
46 Central Module Comfort System
    Serial number: 0310530050
    Long coding: 013B0622A0B93080832009042C010F470000000000000000000000000000
    Subsystems:
        System description: DWA-Sensor
        Software number: 4G0951177
        Hardware version: H01
        System description: LIN BACKUP HO
        Software number: 1K0951605C
        Software version: 1501
        Hardware version: H05
    Trouble codes:
47 Sound System
    System description: BOSE-G3-C7
    Software number: 4G0035223C
    Software version: 0160
    Hardware number: 4G0035223A
    Serial number: 00000000019648
    Long coding: 030000
    Trouble codes:
52 Door Electronics Passenger Side
    System description: TSG BF
    Software number: 4G8959792J
    Hardware number: 4G8959792G
    Long coding: 011F16005E01628002080002
    Trouble codes:
53 Parking Brake
    System description: EPB-4
    Software number: 4H0907801L
    Software version: 0017
    Hardware number: 4H0907801A
    Serial number: 00000002610471
    ODX name: EV_ParkiBrake
    ODX version: 001029
    Trouble codes:
55 Headlight Regulation
    System description: ....AFS13....
    Software number: 4H4907357C
    Software version: 0020
    Hardware number: 4H4907357A
    Serial number: 130628-0004-0076
    ODX name: EV_AdvanFrontSyste
    ODX version: 005001
    Long coding: 11226F33F918EB00
    Trouble codes:
56 Radio
    System description: Radio U DAB
    Software number: 4G0035061L
    Software version: 0133
    Hardware number: 4G0035061
    Hardware version: H60
    Serial number: 109GB0D7689099
    Long coding: 010103010000000001
    Trouble codes:
5F Information Control Unit 1
    System description: H-BNT-EU
    Software number: 4G0035670K
    Software version: 0732
    Hardware number: 4G0035670H
    Hardware version: H51
    Serial number: 190G$0D7544157
    Long coding: 080101050003F9EF3D90EB3E00000003000001000200000000
    Subsystems:
        System description: EUR 2013/2014
        Software number: 8R0060884BC
        Software version: 1603
        System description: DU8 C7 SV
        Software number: 4G0919605C
        Software version: 0021
        Serial number: AUZ8ZDDD001TUXZ
        System description: E380 BDT C7
        Software number: 4G2919612Q
        Software version: 0204
        Hardware version: H11
        Serial number: 90349MG10001A
        System description: CD-Database
        Software number: 8R0060961F
        Software version: 5298
    Trouble codes:
        00862 - Navigation antenna (GPS) Open circuit
            Intermittent
                Priority:  5
                Driving cycle: 138
                Mileage: 126373 km
                Date: 2020-01-25 17:24:03
62 Door Electronics Rear Left
    System description: TSG HL
    Software number: 4G8959795J
    Hardware number: 4G8959795G
    Long coding: 010F14004001628002080002
    Trouble codes:
69 Trailer Function
    System description: Anhaenger
    Software number: 4G8907383
    Software version: 0100
    Hardware number: 4G8907383
    Serial number: 00000193762419
    Long coding: 0109080000000000
    Trouble codes:
6C Camera System Rear View
    System description: SG Rueckfahrkamera
    Software number: 4G0907441B
    Software version: 0061
    Hardware number: 4H0907441
    Serial number: 525 PA8J36G2TF
    Coding: 1090005
    Trouble codes:
6D Deck Lid Control Unit
    System description: HDSG-Modul
    Software number: 4G9959107B
    Software version: 0143
    Hardware number: 4G9959107A
    Serial number: 179300549
    ODX name: EV_HDSGAu572
    ODX version: 001022
    Long coding: 097205C011
    Trouble codes:
        B12EF54 - Luggage compartment cover No basic setting
            static
                Date: 2020-01-25 17:23:55
                Mileage: 126373 km
                Priority: 2
                Voltage terminal 30: 12.09 V
72 Door Electronics Rear Right
    System description: TSG HR
    Trouble codes:
85 On-Board Camera
    System description: DPC-SG
    Software number: 4G0907217A
    Software version: 0038
    Hardware number: 4H0907217A
    Hardware version: H26
    Serial number: 26213002542100000000260012
    ODX name: EV_OnBoardCamerDPC
    ODX version: 001007
    Long coding: EE060000
    Trouble codes:
8B Adaptive Cruise Control 2
    Software number: 4G0907541A
    Software version: 0400
    Hardware number: 4G0907541
    ODX name: EV_AdaptCruisContr2AU57X
    ODX version: 002008
    Trouble codes:
            Intermittent
                Date: 2020-01-25 17:23:59
                Mileage: 126373 km
                Priority: 6
                Dynamic environmental data: 028D000C02852EA9100EFFFE100FFDEA
8E Image Processing Electronics
    System description: BV-SG
    Software number: 4G0907107E
    Software version: 0041
    Hardware number: 4H0907107
    Hardware version: H31
    Serial number: 00500012210613769103370000
    ODX name: EV_BC7
    ODX version: 001001
    Long coding: 04C23A1C1111
    Trouble codes:
8F Pretensioner Front Left
    System description: RGS-VL
    Software number: 4H0980945B
    Hardware number: 4H0980945C
    ODX name: EV_RGS_L
    ODX version: 002004
    Long coding: 0066E608031F0376070308004240C2010000
    Trouble codes:
90 Pretensioner Front Right
    System description: RGS-VR
    Software number: 4H0980946B
    Hardware number: 4H0980946C
    ODX name: EV_RGS_R
    ODX version: 002004
    Trouble codes:
A9 Actuator For Structure-Borne Sound
    System description: SAS-GEN 2
    Software number: 4G0907159A
    Hardware number: 4H0907159A
    Serial number: 130613201659��
    ODX name: EV_SoundActuaGen2AU64X
    ODX version: 002005
    Trouble codes:
C0 Actuator For Exterior Noise
    System description: SAS-GEN 2 AGA
    Software number: 4G0907160B
    Software version: 0004
    Hardware number: 4G0907160B
    Serial number: 130618200598
    ODX name: EV_ActuaForExterNoiseUDS
    ODX version: 003013
    Trouble codes:
On 1/21/2020 at 5:34 PM, Magnet said:
Hello Thomas,
Gareth,
All done - it WAS the GPS fin. Local garage fitted a new one, the old one was corroded inside. Why Audi didn't check that when it came up on the scan!!? N A completely clear scan now...nothing at all.
Amazing how water ingress into the fin caused a bevvy of issues.
Hello Thomas,
Gareth,
