Audi A4 1.8t stiff 1st and 2nd gear when engine is cold
Dagmara
Hello,
I've got audi a4 2009 1.8t tfsi 150k mileage
I've got a problem with a gearbox.
1st and 2nd gear are difficult to change while changing when engine is cold. Works smoother when the engine warms up.
I drop it to the garage, and was told that the oil could possibly be too thick.
I have collected car from a mechanic today who drained and replace the gearbox oil to 75W 90 Semi - syntethic.
Mechanic said there was some metal shavings in the gearbox oil and it could be the first sign of possible "end of the gearbox life" which makes me feel a bit worried...
After having gearbox oil replaced It didn't really help + now there is a creaking noise while changing the gears.?!
I've message them to ask but will prob get an answer after the weekend.
Any ideas?
On 3/13/2020 at 6:58 PM, Dagmara said:
Hello,
Any ideas?
That's just a characteristic of the gearbox. It's not actually a fault.
Don't worry about it, carry on as normal
Seems like the garage gave you some b-ull sh-t, just to charge you for an oil change. But they may of caused your other issue thou.
