esky365 Posted March 17, 2020 Posted March 17, 2020 I have a leak in the passenger foot well. I can't find the cause and it is intermittent. I am wondering if there should be a lid on my pollen filter? Meanwhile, I have drilled a hole in the floor grommet, so it should prevent severe flooding.
Steve Q Posted April 9, 2020 Posted April 9, 2020 I've had the exact same issue. Had to have the pollen filter housing replaced. Not the most expensive part to change but definitely should cute the issue. Cheers Steve 1
esky365 Posted September 21, 2020 Author Posted September 21, 2020 I finally took the filter out to have a look. The problem was the gasket beneath the filter was damaged. I replaced it about a month ago, and so far the problem has not returned.
Steve Q Posted September 22, 2020 Posted September 22, 2020 On 9/21/2020 at 6:43 AM, esky365 said: I finally took the filter out to have a look. The problem was the gasket beneath the filter was damaged. I replaced it about a month ago, and so far the problem has not returned. Expand Glad you got it resolved 🙂
