Darren H Posted March 28, 2020 Share Posted March 28, 2020 Hi all ,first time on here so go easy on me聽馃榿 i bought an A4 2.0 tdi聽 CAGA code from one of my customers with the usual hole in cylinder head,i located another head from same engine code engine and fitted it ,it started eventually and ran smoothly,drove it up the road and pulled well with no issues apart from mil light on,switched it off and went to restart it ,it would maybe start once in 15 attempts but would with easy start,code read it and it came up with P001600聽聽cam crank correlation,checked timing twice and its bang on,changed cam sensor but not crank sensor yet ,other codes were P008700 rail pressure low (only 10 bar on cranking ) and P305300 Starter activation,return message term 50 short to ground,open circuit ,intank聽pump runs under cranking. any tech support would be greatly received,cheers Darren Quote Link to comment Share on other sites More sharing options...
audiA4carpet Posted April 9, 2020 Share Posted April 9, 2020 "with the usual hole in cylinder head" Why do you say "usual"? Quote Link to comment Share on other sites More sharing options...
audia4b5kev Posted April 9, 2020 Share Posted April 9, 2020 pump聽 Quote Link to comment Share on other sites More sharing options...
