Audi A5 8t3 2.7tdi door lock/unlock remote working intermittently
Hi new to here, after a bit of advice,i have the remote and door lock intermittently not working or not locking or unlocking both driver's door and boot, also key was working for a bit then stopped locking and unlocking and opening window, door handle went to so couldn't open from outside (door handle working now 馃檮) so I've decided to change the driver's door lock, (Actuator) does anyone know if I have the right part for the spec and year of my car, A5 8t3 2.7tdi 57 reg,聽
8J2837016A which is the 9 pin one,聽
Would appreciate anyone's help
Think you're on the right lines with changing the door lock mechanism. Did that cute the problem?
Thanks for your interest Steve
Not changed it as of yet as not sure if I have the right part number 8J2837016A is the 9 pin one and there seems to be a 7 pin one as well
So still trying to find out which one it is
If you have any ideas I would be greatful
Truthfully I'm not sure on which one you.need either. Sorry I can't help more.
