Hi all, wondering if anyone could help, I'm getting ready to install sub and amp in my a4 cab, I was wondering if anyone could help with access through the firewall for the power cable? Is there a grommet that comes out anywhere close to the battery? Hope someone can help.
Thanks
Hi Martyn,
I think if you look near to the battery you should find a grommet or two, which come out the back of the glovebox. You may need to remove the back of the glovebox to get at them from that side. In failing that I think there's one near the ECU. You'll have to remove the ECU housing to get at it. To do that you have to remove the wipers to get at all the torx screws.
Another more way out option is to take the wire via the pollen filter housing.
Steve
I've found one just to the right of the battery. Was going to take glovebox out anyway for a tidy job. Thanks for the reply Steve
You're welcome, glad I could help 🙂
