Martyn85 Posted April 20, 2020 Posted April 20, 2020 Hi all,聽wondering if anyone could聽help, I'm getting ready to install聽sub and amp聽in my a4 cab, I was聽wondering if anyone could help with access through the firewall for the power聽cable? Is聽there a grommet that comes out anywhere close to the battery? Hope聽someone can help.聽 Thanks
Steve Q Posted April 20, 2020 Posted April 20, 2020 Hi Martyn,聽 I think if you look near to the battery you should find a grommet or two, which come out the back of the glovebox. You may need to remove the back of the glovebox to get at them from that side. In failing that I think there's one near the ECU. You'll have to remove the ECU housing to get at it. To do that you have to remove the wipers to get at all the torx screws.聽 Another more way out option is to take the wire via the pollen filter housing.聽 Cheers Steve
Martyn85 Posted April 20, 2020 Author Posted April 20, 2020 I've found one just to the right of the battery. Was going to take glovebox out anyway for a tidy job. Thanks for the reply Steve聽
Steve Q Posted April 20, 2020 Posted April 20, 2020 4 hours ago, Martyn85 said: I've found one just to the right of the battery. Was going to take glovebox out anyway for a tidy job. Thanks for the reply Steve聽 You're welcome, glad I could help 馃檪
