Hi I have recently purchased a 2014 Audi S6 saloon  I can buy a set of discs and callipers off a 2016 Rs6 Can anyone tell me if these will fit straight on or can be made to fit any info would be appreciated thanks
Welcome to the forum Darren, you'll find the members on here are a friendly and helpful bunch.
The fronts will definitely bolt on as the front rs6 brakes can fit a regular c7 but with slightly longer breaker hoses. However rs6 rear brakes do not fit a regular c7 especially 2wd. However as yours is a s6 I would like to think they'll bolt straight on. Bearing in mind there was a ceramic brake upgrade for the s6 was £8,650 option when the car was new.
If it is ceramic brakes you're fitting, be warned I believe their stopping capabilities aren't as good in normal conditions but designed for fast road or track use.
Hope I've helped 🙂
Steve
Steve thanks for your reply. There not the ceramic option my pockets ain’t that deep,
You're welcome, glad I could help 🙂 they're very very expensive. As you're upgrading the brakes, are you going for an rs6 conversion? Or going stage 3?
