Mmi issues
Strobe Willow
Hi just wondering if anyone can help? I have a B8 A4 and I have bought an update for the sat nav, the issue I am having is that the cd and sd cards don't work. I have tried to insert the CD and sd cards but the cd won't be taken in and its like pushing the sd card against a wall.
I do have a multi cd player in the glove box and just wondering if the power for cd player has been taken from the mmi unit thus meaning the mmi unit isn't powered.
Any help would be appreciated.
Hi Mike,
Is the CD player in the glovebox illuminated?
If its not excepting discs it's sounds like it's not working. Might be worth removing it and checking the power supply with a multimeter.
Steve
Hi Steve
Thanks for the reply the multi changer works fine its just the mmi unit that doesn't except disc or sd card.
I will pull the mmi out again and check the power supply.
