Miket19 Posted May 10, 2020 Share Posted May 10, 2020 I have a 2010 a4 avant 2.0tdi. engine management light came on due to DPF pressure sensor.. has now been changed but light is still on. Any advice on this? car was sent off for a new clutch and they changed a centre sleeve on the exhaust and now car has flashing coil light down to EGT sensor 4.. and now particulate filter light has come on also... haven’t changed the sensor as of yet due to not knowing location of sensor.. a few people have mentioned it is the second sensor after DPF is this correct? And also would changing this resolve the issues as they are the only 2 codes coming up when plugged in? thanks. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted May 11, 2020 Share Posted May 11, 2020 Hi Mike, as you seem mechanically minded, I think your best course of action would be to dismantle the dpf and examine it's condition. Clean it a f change the second sensor or both and then see if that sorts it. Cheers Steve Quote Link to comment Share on other sites More sharing options...
audiA4carpet Posted August 2, 2020 Share Posted August 2, 2020 I assume you have scanned it for codes, if so put the scan on here so that we can help. Quote Link to comment Share on other sites More sharing options...
