Mungo2007 Posted May 12, 2020 Posted May 12, 2020 Hi Just serviced my 2008 a3 managed to reset the oil service but I am still getting the service due warning on the dash can I reset this as well or does it need plugging in to do this?
Steve Q Posted May 13, 2020 Posted May 13, 2020 1 hour ago, Mungo2007 said: thanks steve will give this a go You're welcome 👍
Mungo2007 Posted May 14, 2020 Author Posted May 14, 2020 Tried this today but no joy, when i follow this i can reset the oil service but not the main service warning. When i pull and hold the dial it flicks to the oil service and resets this only not sure what i am doing wrong. It is a 2008 A3 2.0 TDI dahs looks the same except i get a message on the display saying service due not just service like the video above
Steve Q Posted May 14, 2020 Posted May 14, 2020 Not sure then. Might be worth speaking to your local garage. Cheers Steve
Mungo2007 Posted May 20, 2020 Author Posted May 20, 2020 i think from the other research i have done it may need to be reset on a VCDS system although i have seen A3's being reset on some you tube videos wouldn't normally both me but i am looking to sell the car
Steve Q Posted May 20, 2020 Posted May 20, 2020 28 minutes ago, Mungo2007 said: i think from the other research i have done it may need to be reset on a VCDS system although i have seen A3's being reset on some you tube videos wouldn't normally both me but i am looking to sell the car I'm thinking you're right, ironically mine just came on despite the car just being serviced and the garage had to plug it in. Cheers Steve
Mungo2007 Posted May 20, 2020 Author Posted May 20, 2020 Ok thanks Steve Does it need a VAGCOM system or will any system reset it ?
Steve Q Posted May 21, 2020 Posted May 21, 2020 15 hours ago, Mungo2007 said: Ok thanks Steve Does it need a VAGCOM system or will any system reset it ? Think any will. Not sure what my mechanic uses.
