Gary East Posted May 24, 2020 Posted May 24, 2020 Hi all, this is my first post, ive an A6 3.0 avant 2019, im getting reduce oil level message every time now i start the engine, but when i pop the bonnet and remove and replace the cap the message goes away..... until next time a start up, wonder when the service side of Audi will be operational again. thanks
Steve Q Posted May 24, 2020 Posted May 24, 2020 I'd be getting this looked at by a garage that's open. As long as they use genuine Audi parts/oil and they're vat registered it won't void your warranty. Believe it or not too much oil can damage the engine. Cheers Steve
Gary East Posted May 25, 2020 Author Posted May 25, 2020 I’m waiting for local Audi to open but. What puzzles me is I’ve never touched the oil in the 11 month I’ve had it and it cannot just fill itself up 😀 should I drive it you think if I open the bonnet tKe the oil cap off then replace it the warning goes away till next time
Steve Q Posted May 25, 2020 Posted May 25, 2020 It is weird it's just come on. When was it's last service done?
Gary East Posted May 25, 2020 Author Posted May 25, 2020 Morning Steve, its never had one yet only done 8,000 miles
Steve Q Posted May 25, 2020 Posted May 25, 2020 6 hours ago, Gary East said: Morning Steve, its never had one yet only done 8,000 miles Very weird then. I'd be getting bit in to be looked at asap. I appreciate Audi isn't open yet though
Gary East Posted May 26, 2020 Author Posted May 26, 2020 UPDATE! faulty fuel sensor i got audi roadside out 🙂 changed it all is good theres a software update too that helps initial acceleration it was always sluggish pulling away. thanks
Steve Q Posted May 26, 2020 Posted May 26, 2020 43 minutes ago, Gary East said: UPDATE! faulty fuel sensor i got audi roadside out 🙂 changed it all is good theres a software update too that helps initial acceleration it was always sluggish pulling away. thanks Hadn't even thought of Audi road side assistance. Glad you got it sorted 😊
Magnet Posted May 26, 2020 Posted May 26, 2020 Hello Gary, Faulty fuel sensor? Not oil level sensor. Kind regards, Gareth.
Magnet Posted May 27, 2020 Posted May 27, 2020 Hello Gary, It’s great that you have kindly informed the forum of the successful outcome to the issue (few do!). Your reply will hopefully be of help to others who experience similar symptoms in the future. Apologies for being pedantic:- You say (and confirm?) it was due to a faulty FUEL sender. Logic would point to this being wrong. Faulty OIL level sensor would make sense - but not a faulty fuel sensor. Wondered if you could clear up this important anomaly for us. Many thanks and kind regards, Gareth. 1
Gary East Posted May 27, 2020 Author Posted May 27, 2020 haha no problem Gareth, it says on report replaced G247 fuel pressure sensor, he wasnt sure if it was actually that but all is good now, he did say in some cases loads of minor journeys can cause the oil not to regenerate as efficiently and cause levels to rise in time which would explain a lot as ive not had this out of the town in 3 months.
Magnet Posted May 27, 2020 Posted May 27, 2020 Hello Gary, Confusing! Is this a diesel by any chance? If so, perhaps not so confusing. Perhaps you could let us know. Kind regards, Gareth.
Magnet Posted May 27, 2020 Posted May 27, 2020 Hello Gary, Um! Puts a different slant on it altogether, now that we have more detail. So we now know that Audi Assist actually removed oil from the engine, indicating that the warning of an overfill was correct and real, and not a faulty oil level sensor. We know you have never put oil in the car, yet it was overfilled, so your statement ‘.....and it cannot just fill itself up...’ can no longer be fact. How does the oil level increase? I am not claiming knowledge of VAG diesel engines having such problems, but I am aware of one prestigious marque engine which suffers from oil ‘dilution’ due to unburnt diesel getting into the lubrication system and obviously diluting the and increasing the oil level. Not good news in their case, and as I understand it, the oil gets checked for such diesel contamination. Now having more fact, leads me to question if this engine is suffering from a similar issue, since it appears you have proof positive that the oil level has indeed increased, despite you not adding any. If this were mine, I would be searching for more information/incidence of problems with current VAG diesels, so that you are better equipped to follow this up with Audi. Perhaps you could keep us posted Gary. Kind regards, Gareth.
Gary East Posted May 28, 2020 Author Posted May 28, 2020 Hi Gareth, its booked in the Wearside Audi garage on 11th im going to get it checked out ill update the forum when complete thanks for all your help
Magnet Posted May 28, 2020 Posted May 28, 2020 I would most certainly being doing my search homework first. You need to be able to stand your corner, and get a plausible explanation for why the oil level increased - which it certainly did, and dictated the Audi Assist man to drain some off. Don’t be fobbed off with some Cummingsesque excuse! Suffering oil dilution/contamination with diesel can have serious consequences for engines. Personally, I would not be happy with a simple oil and filter change - which is most likely they will do. Kind regards, Gareth.
Gary East Posted June 11, 2020 Author Posted June 11, 2020 Ok so got it back today, they said , and excuse me im no way mechanically minded, the DPF filter was producing too much soot on very short journeys and somehow effected the oil level, had a software update too and the delayed acceleration is fixed now.
Magnet Posted June 11, 2020 Posted June 11, 2020 Many thanks for updating the forum Gary. ‘DPF producing too much soot...’ ( and so increasing the oil level!??) Um! Now here is the simply question to ask them:- Where did the increased oil volume actually come from? I’m sure a lot of folks would be interested in that theory, since if you can actually ‘make’ oil from nowhere, then we’d all be in the money. I think I would rather go with my possibility. Kind regards, Gareth.
Jinxit Posted June 12, 2020 Posted June 12, 2020 The oil will absorb soot and increase in volume. This was very common on older diesels and is why diesel engined cars always have much darker oil than a petrol engine. However I am not sure how soot from the DPF could get into the oil. Maybe it can but I don't know.
emil Posted 4 hours ago Posted 4 hours ago You can easily perform an oil spot test if you suspect fuel or water contamination (see below). In the situation above I suspect fuel contamination which can be for several reasons: faulty injectors, short trips or many start stop sequences which can lead to diesel oil being unburned Spot test: When you place a drop of oil on a clean, white surface or specialized paper, its spread, color, and texture can indicate several important factors: Contamination: A milky or cloudy appearance may suggest the presence of water or coolant in the oil. An overly thin, watered-down spot can indicate fuel dilution, which may occur if unburned fuel is mixing with the oil. Oxidation and Degradation: Darker, thicker spots can signal that the oil has oxidized or broken down, which reduces its lubricating efficiency and can lead to sludge formation. Changes in the consistency or the presence of particulate matter might also point to additive degradation or the beginning of contamination from engine wear. Viscosity Changes: The way the oil spreads can offer a rough idea about its viscosity; thicker oil will spread less, while thinner oil will cover a larger area.
emil Posted 4 hours ago Posted 4 hours ago PS: When you make a spot test, it is better to compare it against a fresh oil spot.
emil Posted 4 hours ago Posted 4 hours ago Ps: the new diesel engines like mine (2022 A6 Avant quattro 40 TDI hybrid) are consuming by default quite a lot of oil. During a trip to Italy when the car was almost new (10000 miles only) the oil consumption was about 1 liter for 6000 miles. That's why I suspect the reason was fuel leaks inside the burning chamber and consequently inside crank case.
