Steve93 Posted May 25, 2020 Posted May 25, 2020 Hi guys Looking for abit of help/advice on this.聽 Turned the car off the other day and everything was working fine.... have gone to turn the car back on and the MMI is stuck on initialising on the dash. the screen pops up on start up and the loading screen in on but goes no further. Tried the 3 button rest set to no avail.. 馃槥 馃槥 I've spent countless hours now scrolling through different forums with not much help apart from this 拢2800 price being flown around alot to 'replace and reprograme Wondering if anyone has any clue on what to do or how to fix... becoming tedious not being able to listen to music/radio in the car Cheers in advance.聽
Steve Q Posted May 26, 2020 Posted May 26, 2020 If you've tried the reset and looked at info online to no avail then the last resort is to take it to your local garage or Audi dealer im afraid.聽 Cheers Steve
Steve93 Posted May 26, 2020 Author Posted May 26, 2020 That's today's plan, error code check and go from there.聽 Hopefully will just be a new unit... finger crossed!
Steve Q Posted May 27, 2020 Posted May 27, 2020 On 5/26/2020 at 9:14 AM, Steve93 said: That's today's plan, error code check and go from there.聽 Hopefully will just be a new unit... finger crossed! Please keep us posted on how you get on 馃憤 Cheers Steve
Steve93 Posted May 28, 2020 Author Posted May 28, 2020 Sooo... the update 馃槀馃槀 Codes read fine, there were a few open circuit faults which were screen, probably due to the glove box being dismantled.. Simple answer the is no communication from the mmi unit to the vehicle, so I've ordered a new one and seeing if that works.聽 Failing this I've been pointed to www.bba-reman.co.uk so I gave them a phone. Seems these giys fix most things ECU's, throttle bodies, mmi units , blah blah blah.聽 Quoted around 拢225 with a life time guarantee 馃憣馃徎 seens rather fair in my opinion..
Steve Q Posted May 28, 2020 Posted May 28, 2020 11 hours ago, Steve93 said: Sooo... the update 馃槀馃槀 Codes read fine, there were a few open circuit faults which were screen, probably due to the glove box being dismantled.. Simple answer the is no communication from the mmi unit to the vehicle, so I've ordered a new one and seeing if that works.聽 Failing this I've been pointed to www.bba-reman.co.uk so I gave them a phone. Seems these giys fix most things ECU's, throttle bodies, mmi units , blah blah blah.聽 Quoted around 拢225 with a life time guarantee 馃憣馃徎 seens rather fair in my opinion.. Good luck, please keep us posted on how you get on 馃檪聽 Cheers Steve
