Good afternoon all have downloaded my Audi app,to my smartphone have got 8 digit Pin how do I install it on my mmi screen car is a 2017 A6 Quattro thanks.
Once you register in myaudi.com, it will give you the PIN.
THe PIN is under NAV menu, destination, online destination and there you will see from 'my audi account' - once you click it, it will ask you for a PIN
Or when you open connect on the MMI the first option listed should be login. If it isn't there, go to the last option which should be logout and press it. Go back to top of list then select login.
cheers
Steve
Thanks Steve do I need a SIM card installed for this to work thanks for help .
Hi all, just joined the Forum, back to being an Audi owner again 🙂
I have just set this up on my A6 and you dont need a SIM if your phone is relatively modern (and not Apple, which seems more complicated), the car can use a 'remote SIM profile' off your Android phone. I followed the instructions here: https://paulroberts69.wordpress.com/2017/11/17/configuring-the-audi-mmi-wifi-hot-spot/ and now happily have all data connection and Google Earth maps in the car, and no SIM in the dash.
