Harris Posted June 7, 2020 Posted June 7, 2020 Hi guys Im stripping out my cooling system so dismantled my front end to get the radiator out at the top left hand corner of the rad is a pipe that splits into two the thicker pipe feeds from the engine and the thinner pipe feeds from the coolant tank they both feed into a plastic housing which attaches to the rad. I need to remove this to get the rad out but not sure how and don’t want to break it im guessing it just twists out but don’t want to break it in case I’m wrong any ideas????
Harris Posted June 7, 2020 Author Posted June 7, 2020 Also same assembly bottom right ive found a metal clip that slots it I’ve removed both of them very rusty and I think might have snapped as one side is longer than the other plastic fittings still not budging
