After modification of the wheel hub. The thickness of the mounting screw is different. With the thickness just away from the brake disc. Thickened shims also serve this purpose. There is also to make the hub protrude from the width of the car. Increase the width of the car to increase the stability of the steering. Not easy to roll over. It cannot solve the problem of skidding. Just like the difference between a van and a car. Van. The body is tall. The width of the tires on both sides is small. Turning fast will turn over. If you widen it, it won't. In fact, adding a gasket does not affect safety. Mainly your screw. The quality is better. Mainly depends on the quality of your modified screw.
So it is very important to use good quality screws.
Kwok,
Any chance you could reply to one of your other threads to give an answer to whether you have any commercial connection with the link you promoted there, rather than starting new associated threads under different headings?
