Hi all
I need some help with a problem i have with a lamp out warning light that constantly comes on to tell me there is a bulb out. All bulbs are working fine had it plugged into VCDS and it is indicating the drivers side mirror repeater is the problem but this is still working ok. Is this just a case of replacing the LED's in the mirror or is there another fix to sort this annoying problem.
Thanks
Hello Duncan,
These ‘bulb-out’ warnings normally work by monitoring expected current/resistance across all lighting equipment. A working light with a higher than expected contact resistance can result in this warning, even when the light is illuminated. LEDs ? No a full strip’s worth? - similar I guess.
