Adaptive systems failure
ThomasG
Me again!
Now yet another error appearing - well three - on the dash - all yellow and all adaptive systems.
Nothing has been done to the car apart from new discs and shoes all round.
Driving to shop (7 miles away) and back, at about 9 miles the air suspension light comes on - rapidly followed by the adaptive headlamp failure and then the ACC and Brake . I drive home and try changing car height - works - each driving mode works.
Plug in and clear all codes - nope. Switch off and clear again - all clear. No issues when starting.
Just now - been on a short run - and at about 8 miles all three again. Home and tried to clear. Same cycle as yesterday.
So - layman's theory - these are all adaptive systems, so probably some sensor issue. Or is it related to having new brakes on the front, and I doubt any calibration took place after installation, if that was necessary.
So - A6 hivemind - anyone had this, or anyone know what to look for?
For ref (edited down)
04 Steering Angle Sensor
 Trouble codes:
        No trouble codes found
09 Central Electrics
    Trouble codes:
 01771 - Headlamp range control module Please read DTC
            static
34 Chassis Control
    Trouble codes:
        C103515 - Right front level control sensor Open circuit/short circuit to B+
            static
55 Headlight Regulation
    Trouble codes:
        U111200 - Function limitation due to implausible message
            static
85 On Board Camera
    Trouble codes:
        U111300 - Function limitation due to received malfunction value
            static
Actually, that was the wrong info. Here is full scan. I know there is some issues withe the a/c - it's the other stuff that is new and worrying.
01 Engine
    System description: 3.0BTD EDC17
    Software number: 4G0907589C
    Software version: 0001
    Hardware number: 4G0907589
    Hardware version: H25
    ODX name: EV_ECM30BTD0114G0907589C
    ODX version: 001001
    Long coding: 322A403225760B020000
    Trouble codes:
02 Transmission
    System description: 0BK 30RTDIRdW
    Software number: 4G0927158L
    Software version: 1003
    Hardware number: 0BK927156AM
    Hardware version: H16
    ODX name: EV_TCMAL551211
    ODX version: 002022
    Long coding: 000001
    Trouble codes:
03 Brakes
    System description: ESP PREMIUM
    Software number: 4G0907379M
    Software version: 0450
    Hardware number: 4G0907379M
    Hardware version: H09
    Serial number: --------------
    ODX name: EV_ESPPremiAU57X
    ODX version: 004039
    Long coding: 49A7DF0592E5FBA0FB00
    Trouble codes:
    Trouble codes:
05 Keyless System
    System description: BCM2 2.0
    Software number: 4H0907064CN
    Software version: 0433
    Hardware number: 4H0907064CN
    Hardware version: H33
    Long coding: 01B93046000000000000
    Subsystems:
        System description: J764 ELV MLB
        Software number: 4H0905852C
        Software version: 0046
        Hardware version: H40
        Serial number: 2313000106737005
    Trouble codes:
08 Air Conditioning
    System description: KLIMA 4 ZONEN
    Software number: 4G0820043AD
    Software version: 0087
    Hardware number: 4G0820043AD
    Hardware version: H13
    Serial number: 22061300040258
    ODX name: EV_AirCondiComfoUDS
    ODX version: 002040
    Long coding: 3622007825
    Trouble codes:
            static
                Date: 2020-06-19 20:01:36
                Mileage: 132847 km
                Priority: 6
                Malfunction frequency counter: 1
                Unlearning counter: 191
                Dynamic environmental data: 02860BC326098C26131AF4
        B109E13 - A/C compressor first run Open circuit
            static
                Mileage: 132847 km
                Priority: 6
        B126411 - Windshield defogger activation Short circuit to ground
            static
                Mileage: 132847 km
                Priority: 6
        B126412 - Windshield defogger activation Short circuit to B+
            static
                Mileage: 132847 km
                Priority: 6
    System description: BCM1 2.0
    Software number: 4H0907063CE
    Software version: 0130
    Hardware number: 4H0907063E
    Hardware version: H12
    Serial number: 00000001745791
    Long coding: 0200201050B49FE2C98100C000001908CF9D67082F080201000008406100
    Subsystems:
        System description: WWS57X 130618
        Software number: 4G2955119
        Software version: 0080
        Hardware version: H36
        Serial number:         130620152538
        Long coding: 0045F7
        System description: G397_RLFS
        Software number: 8U0955559B
        Software version: 0002
        Hardware version: H06
        Serial number: 21462662
        Long coding: 02006D
        System description: E1 - LDS
        Software number: 4G0941531S
        Software version: 0044
        Hardware version: H07
        Serial number: 28 06 2013  00001337
        System description: AQ_Hum_Sensor
        Software number: 4H0907658
        Software version: 0003
        Hardware version: H03
        Serial number: 7719C4B6000000000001
    Trouble codes:
        01229 - Humidity sensor, A/C system Faulty
            static
                Priority:  3
                Frequency counter:  1
                Driving cycle: 191
                Mileage: 132847 km
                Date: 2020-06-19 20:01:00
            static
                Priority:  6
                Driving cycle: 192
                Mileage: 132860 km
                Date: 2020-06-20 15:36:00
10 Parking Assistance
    System description: PARKHILFE PLA
    Software number: 4H0919475AB
    Software version: 0060
    Hardware number: 4H0919475E
    Serial number: 56261318003980
    ODX name: EV_EPHVA2CAU57X0000
    ODX version: 002012
    Long coding: B93B0C
    Trouble codes:
13 Adaptive Cruise Control
    System description: ACC3
    Software number: 4G0907561A
    Software version: 0410
    Hardware number: 4G0907561
    Hardware version: H19
    Serial number: 00000000000000
    ODX name: EV_AdaptCruisContrAU57X
    ODX version: 002010
    Long coding: 7F04010202
    Trouble codes:
            static
                Date: 2020-06-20 15:36:48
                Mileage: 132860 km
                Priority: 6
                Malfunction frequency counter: 2
                Unlearning counter: 192
                Dynamic environmental data: 028D001A028537F7100E1619100FFCF4
15 Airbag
    System description: Airbag10.43
    Software number: 4H0959655C
    Software version: 0040
    Hardware number: 4H0959655C
    Hardware version: H43
    Serial number: 003JG00DVSXE
    ODX name: EV_AirbaAU10BPAAU64X
    ODX version: 001014
    Long coding: 3032343631334E303539554A305234473053
    Trouble codes:
16 Steering Column
    System description: Lenks.Modul
    Software number: 4H0953568G
    Software version: 0005
    Hardware number: 4H0953568G
    Hardware version: H04
    Serial number: 90372MFR001G3
    Long coding: 0000FD
    Subsystems:
        System description: E221 - MFL
        Software number: 4G0951528E
        Software version: 0010
        Serial number: 22 05 2013  33011847
    Trouble codes:
17 Dashboard
    System description: TDieGb AccNv
    Software number: 4G9920950P
    Software version: 0618
    Hardware number: 4G9920950P
    Hardware version: H80
    Serial number: 6581406135960075
    ODX name: EV_RBD4K
    ODX version: 004048
    Long coding: 338720081F512600010600
    Trouble codes:
19 Gateway
    System description: J533--Gateway
    Software number: 4G0907468AC
    Software version: 0037
    Hardware number: 4G0907468AC
    Serial number: 00000000999979
    ODX name: EV_GatewPkoUDS
    ODX version: 001018
    Long coding: 00CD077D00
    Subsystems:
        System description: J367-BDMHella
        Software number: 8T0915181
        Software version: 8041
        Serial number: 8141390603
    Trouble codes:
28 Rear Climate Control
    System description: KLIMA FOND
    Software number: 4G0919158J
    Hardware number: 4G0919158J
    Serial number: 03071300040346
    ODX name: EV_ClimaContrUnitRearUDS
    ODX version: 002019
    Long coding: 22
    Trouble codes:
        B10D322 - Left rear upper body vent motor Upper limit exceeded
            Intermittent
                Date: 2020-06-20 15:05:26
                Mileage: 132847 km
                Priority: 3
                Unlearning counter: 232
                Dynamic environmental data: 02860D4926099026A62EE92EE92C902710
        B10D422 - Right rear upper body vent motor Upper limit exceeded
            Intermittent
                Date: 2020-06-20 15:05:27
                Mileage: 132847 km
                Priority: 3
                Dynamic environmental data: 02860D4E26099026A72EDD2EDD2C842710
34 Chassis Control
    System description: LUFE-DAEMPFER
    Software number: 4G0907553F
    Software version: 0782
    Hardware number: 4G0907553F
    Hardware version: H18
    Serial number: ‰ST
    ODX name: EV_AirSuspe
    ODX version: 003024
    Long coding: 008003
    Trouble codes:
            static
                Date: 2020-06-20 15:36:46
                Mileage: 132860 km
                Priority: 2
3B Sensor Electronics
    System description: SARA 6D
    Software number: 4G0907637K
    Software version: 0056
    Hardware number: 4G0907637F
    Hardware version: H02
    Serial number: EJ1BPA82044ZLP����������
    ODX name: EV_SARA2
    ODX version: 005012
    Trouble codes:
3C Lane Change Assistant Right
    System description: J769  SWA MasterH04
    Software number: 4G0907566E
    Hardware number: 4G0907566
    Serial number: 6PZ 010 287-04
    Coding: 0011104
    Subsystems:
        System description: J770  SWA Slave H04
        Software number: 4G0907568E
    Trouble codes:
42 Driver Door
    System description: TSG FA
    Software number: 4G8959793H
    Software version: 0507
    Hardware number: 4G8959793F
    Long coding: 011F16005C01628002080013
    Trouble codes:
44 Steering Assistance
    System description: RCEPS
    Software number: 4G0909144L
    Hardware number: 4G0909144G
    Hardware version: H38
    Serial number: 0029630591
    ODX name: EV_RCEPS
    ODX version: 009008
    Long coding: 101101010000
    Trouble codes:
46 Comfort System
    Serial number: 0310530050
    Long coding: 013B0622A0B93080832009042C010F470000000000000000000000000000
    Subsystems:
        System description: DWA-Sensor
        Software number: 4G0951177
        Hardware version: H01
        System description: LIN BACKUP HO
        Software number: 1K0951605C
        Software version: 1501
        Hardware version: H05
    Trouble codes:
47 Sound System
    System description: BOSE-G3-C7
    Software number: 4G0035223C
    Software version: 0160
    Hardware number: 4G0035223A
    Serial number: 00000000019648
    Long coding: 030000
    Trouble codes:
52 Passenger Door
    System description: TSG BF
    Software number: 4G8959792J
    Hardware number: 4G8959792G
    Long coding: 011F16005E01628002080002
    Trouble codes:
53 Parking Brake
    System description: EPB-4
    Software number: 4H0907801L
    Software version: 0017
    Hardware number: 4H0907801A
    Serial number: 00000002610471
    ODX name: EV_ParkiBrake
    ODX version: 001029
    Trouble codes:
    System description: ....AFS13....
    Software number: 4H4907357C
    Software version: 0020
    Hardware number: 4H4907357A
    Serial number: 130628-0004-0076
    ODX name: EV_AdvanFrontSyste
    ODX version: 005001
    Long coding: 11226F33F918EB00
    Trouble codes:
            static
                Date: 2020-06-20 15:36:47
                Mileage: 132860 km
                Priority: 6
56 Radio
    System description: Radio U DAB
    Software number: 4G0035061S
    Software version: 0154
    Hardware number: 4G0035061
    Hardware version: H60
    Serial number: 109GB0D7689099
    Long coding: 010103010000000001
    Trouble codes:
5F Multimedia
    System description: H-BNT-EU
    Software number: 4G0035670Q
    Software version: 1034
    Hardware number: 4G0035670H
    Hardware version: H51
    Serial number: 190G$0D7544157
    Long coding: 080101050003F9EF3D90EB3E00000003000001000200000000
    Subsystems:
        System description: EUR 2020
        Software number: 8R0060884GS
        Software version: 3001
        System description: DU8 C7 SV
        Software number: 4G0919605C
        Software version: 0021
        Serial number: AUZ8ZDDD001TUXZ
        System description: E380 BDT C7
        Software number: 4G2919612Q
        Software version: 0204
        Hardware version: H11
        Serial number: 90349MG10001A
        System description: CD-Database
        Software number: 8R0060961F
        Software version: 5298
    Trouble codes:
        03276 - Checking software version management
            static
                Priority:  6
                Driving cycle: 191
                Mileage: 132847 km
                Date: 2020-06-19 20:01:53
        03623 - Release code faulty
            static
                Priority:  6
                Driving cycle: 191
                Mileage: 132847 km
                Date: 2020-06-19 20:01:52
62 Rear Left Door
    System description: TSG HL
    Software number: 4G8959795J
    Hardware number: 4G8959795G
    Long coding: 010F14004001628002080002
    Trouble codes:
69 Trailer Control
    System description: Anhaenger
    Software number: 4G8907383
    Software version: 0100
    Hardware number: 4G8907383
    Serial number: 00000193762419
    Long coding: 0109080000000000
    Trouble codes:
6C Rear View Camera
    Software number: 4G0907441B
    Software version: 0061
    Hardware number: 4H0907441
    Serial number: 525 PA8J36G2TF
    Coding: 1090005
    Trouble codes:
6D Deck Lid Control
    System description: HDSG-Modul
    Software number: 4G9959107B
    Software version: 0143
    Hardware number: 4G9959107A
    Serial number: 179300549
    ODX name: EV_HDSGAu572
    ODX version: 001022
    Long coding: 097205C011
    Trouble codes:
72 Rear Right Door
    System description: TSG HR
    Trouble codes:
85 On Board Camera
    System description: DPC-SG
    Software number: 4G0907217A
    Software version: 0038
    Hardware number: 4H0907217A
    Hardware version: H26
    Serial number: 26213002542100000000260012
    ODX name: EV_OnBoardCamerDPC
    ODX version: 001007
    Long coding: EE060000
    Trouble codes:
            static
                Mileage: 132860 km
                Priority: 6
                Control module temperature: 52.0 °C
                Voltage terminal 15: 14.3 V
                Outside air temperature: -39.5 °C
8B Adaptive Cruise Control
    Software number: 4G0907541A
    Software version: 0400
    Hardware number: 4G0907541
    ODX name: EV_AdaptCruisContr2AU57X
    ODX version: 002008
    Trouble codes:
8E Image Processing
    System description: BV-SG
    Software number: 4G0907107E
    Software version: 0041
    Hardware number: 4H0907107
    Hardware version: H31
    Serial number: 00500012210613769103370000
    ODX name: EV_BC7
    ODX version: 001001
    Long coding: 04C23A1C1111
    Trouble codes:
        C110800 - Function limitation due to missing image information
            static
                Mileage: 132860 km
                Priority: 6
                Control module temperature: 29.0 °C
                Outside air temperature: 21.0 °C
8F Pretensioner Left
    System description: RGS-VL
    Software number: 4H0980945B
    Hardware number: 4H0980945C
    ODX name: EV_RGS_L
    ODX version: 002004
    Long coding: 0066E608031F0376070308004240C2010000
    Trouble codes:
90 Pretensioner Right
    System description: RGS-VR
    Software number: 4H0980946B
    Hardware number: 4H0980946C
    ODX name: EV_RGS_R
    ODX version: 002004
    Trouble codes:
A9 Structure Borne Sound
    System description: SAS-GEN 2
    Software number: 4G0907159A
    Hardware number: 4H0907159A
    Serial number: 130613201659��
    ODX name: EV_SoundActuaGen2AU64X
    ODX version: 002005
    Trouble codes:
C0 Exterior Noise
    System description: SAS-GEN 2 AGA
    Software number: 4G0907160B
    Software version: 0004
    Hardware number: 4G0907160B
    Serial number: 130618200598
    ODX name: EV_ActuaForExterNoiseUDS
    ODX version: 003013
    Trouble codes:
Hi Thomas these all sound like can communication errors and as a rule of thumb you shouldn't replace parts purely on U codes as these just mean one sensor has lost communication at some point with the other with the exception of the humidity sensor these are located under the cowling behind the mirror, thats the one that controls the demisting and are universally known to fail, I finally got round to changing mine at the beginning of the lock down as it was causing all sorts of erroneous codes relating to the aircon not working because the other components couldn't talk to the humidity sensor, changed it cleared the codes and bingo.
With regard to the other lights I strongly suspect the battery one of my customers has a 2017 S-Line this started to throw up random lights for steering etc so he booked it in with the dealer, before he could get it there the dash was lit up like Trafalgar Square at Christmas and the car won't start turns out its the battery, even though the car has only covered 40k because he never went far in it the battery had been terminated, if your battery is new the next port of call would be getting the alternator charge rate checked as all the above codes can be generated by fluctuations in voltage, can communication relies on a steady consistent voltage.
I don't claim to be an expert by any stretch of the imagination but the one thing you can be sure of is any thing can operated is bad news, at least with the Ford I had most can based sensors become crammed with redundant information so is all I did was a value relearn on the as factory option on Forscan and this cured 95% of the silly codes, not found out how to do this with VCDS yet.
Looking at the scan again, it seems front right level sensor may be the culprit. Its all fine now. No lights. It triggers when driving.
I'll keep digging.
I'll keep digging.
Keep us posted on how you get on 🙂 looks like you're doing well with your investigation 👍
Looking at it again it looks as though the allroad has a levelling sensor on all four corners having picked the guy up the roads brain he works for a independent garage and reckons it could be the sensor as you said, apparently they are not very robust and operate internally on a windings system that if stressed can fail I.E. if the wishbone is hanging down while changing the discs, rarely it can be crud in the connector but it might be the internal pick up inside the box has gone beyond a limit it was never designed  to go and is now playing up which concurs with the error appearing when driven and the sensor is moving.
That was the thing that baffled me with my light problem the car has no sensor on the front and no signs one was ever present I am looking at the possibility that the levelling sensors are built into the headlamp but have yet to find the triggering device, all good fun.
Aye, but how do I go about testing this, and I can't seem to find a replacement one.
Hi there is no way of testing the workings of the control box without some pretty sophisticated kit, just had a word with the guy up the road he said sometimes they disconnect the sensor at the bottom arm end and tie the arm at approx level with a bit of gaffer tape then drive it if the fault does not appear thats your kiddie, the part no is on the unit if no joy message me with your vin and I will look for the part no on my new toy, there are loads of them on eBay and the prices are not spiteful new or second hand and according to those who know they are plug in and play, no coding.
Right, driven along the local runway (where Jim Clark used to practice). So was totally level. No issues. Road for a bit, and errors after a few miles.
Hi Thomas going to be out of the loop for a bit as I am off to work but I hope the part numbers got to you ok and will do some cross matching on the filter applications tonight.
Regards Steve.
16 minutes ago, Stevey Y said:
Hi Thomas the part numbers were sent to your inbox last night will resend
No, nothing. That's odd. I can see you've read my message. But nothing from you.
Do you just want to post part numbers here?
Hi Thomas I did send this twice but please receive the following,
4H0941285G Leveling sensor LEFT
4H0941286G Leveling sensor RIGHT
Try this Blueprint number for your filter ADV182343.
Thank-you so much!!
T
  • 3 weeks later...
Hi Thomas, glad you got it sorted and the heartwarming news of the DIY service makes me glad at least the thieving scrotes at the garages won't be relieving you of a ton of cash any time soon, I knew you were more than capable by the way you describe the problems you had a bit of savvy goes a long way.
I am off to tackle the dreaded rear wiper motor which keeps stopping when it rains because some moron designed it so the water washer system comes through the middle of the wiper spindle and when the seals get older it runs back into the control box and rots it out, I definitely aint taking it apart and cleaning it up only to get the same problem this winter, just going to get a new one as if you work out how long the original unit has lasted it will be another four years until the new one expires.
Regards Steve.
A long thread, but with a good conclusion.
I would say, that the electronic oil level is a nightmare - put in 6 litres, and run for a bit - it will say it's low, then top up very slowly in real time - you really don't want to have to suck some out - not that we had to.
Thanks everyone for all the help. All the parts were about £75 and the oil was £50. New sensor was £50, so a LOT less than Audi, probably half the garage costs.
  • 1 year later...
Hi Thomas, I've got myself a 2013 Allroad and just had the complete set of front suspension arms replaced and have the same error as you, prior to this it was all fine. Found the part numbers already but there appears to be lots of non OEM sellers of this part and was looking for your recommendation as you have done this recently.. I'm not a million miles away from you either in Midlothian.
Any advice you can give would be much appreciated. I've got full VCDS so can do scans etc..
MrB.
Edited by MrBroon
