A4AvantV6 Posted June 21, 2020 Share Posted June 21, 2020 Hi My fuel gauge works 70% of the time, when I put in a full tank of fuel then it is perfectly fine but once about a quarter of the fuel is used then it drops to 0 with an error message. I have seen online that it could be the fuel sender unit, is this difficult to change on a 3.0 TDI? Thanks Quote Link to comment Share on other sites More sharing options...
Steve Q Posted June 22, 2020 Share Posted June 22, 2020 I suspect it'll be located at the top of tank and will require not trim or rear seats to be removed to get at it. Usually fuel senders are bolted to the top of the tank and easy to remove once access is gained. Cheers Steve Quote Link to comment Share on other sites More sharing options...
A4AvantV6 Posted June 22, 2020 Author Share Posted June 22, 2020 22 minutes ago, Steve Q said: I suspect it'll be located at the top of tank and will require not trim or rear seats to be removed to get at it. Usually fuel senders are bolted to the top of the tank and easy to remove once access is gained. Cheers Steve Thanks for that Steve, I will give it a go once I get the parts. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted June 23, 2020 Share Posted June 23, 2020 9 hours ago, A4AvantV6 said: Thanks for that Steve, I will give it a go once I get the parts. No probs. Quote Link to comment Share on other sites More sharing options...
