franszo Posted July 7, 2020 Share Posted July 7, 2020 Hi there, hope someone can help me out on this one, read a lot on forums about HVAC pumps, and control valves, etc. My car started only blowing lukewarm air (even on Lo) on 3 vents out of the 4, the most passenger side vent blows much colder than the rest. gave the HVAC control valves a quick clean, which helped a little bit, but still not the best, only blowing like 17-18 degrees on Lo setting. I went to a specialist who quoted the following (see attached). they said the part needed is nearly £400. but it is still suspicious for me that they want to replace this part : https://www.amazon.co.uk/Coolant-4F1959617B-4F1-959-617/dp/B01K1DQ0OA/ref=asc_df_B01K1DQ0OA/?tag=googshopuk-21&linkCode=df0&hvadid=399634921412&hvpos=&hvnetw=g&hvrand=8805919360818051198&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006764&hvtargid=pla-422215341513&psc=1&tag=&ref=&adgrpid=93504845188&hvpone=&hvptwo=&hvadid=399634921412&hvpos=&hvnetw=g&hvrand=8805919360818051198&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006764&hvtargid=pla-422215341513 can anyone confirm if they talking about the same thing? wouldn't be nice paying £530 for a £50 part that I can replace myself. Many thanks in advance! Quote Link to comment Share on other sites More sharing options...
FirstG Posted May 29, 2023 Share Posted May 29, 2023 There doesn't seem to be too much interest in here!!! Did you manage to sort your AC problem out? Quote Link to comment Share on other sites More sharing options...
Steve Q Posted June 2, 2023 Share Posted June 2, 2023 On 5/29/2023 at 5:48 PM, FirstG said: There doesn't seem to be too much interest in here!!! Did you manage to sort your AC problem out? Have you done a diagnostic check to see if any fault codes flag up? Quote Link to comment Share on other sites More sharing options...
FirstG Posted June 2, 2023 Share Posted June 2, 2023 I have an issue with my AC that might be connected. I had an issue in 2021 with the fan staying on all the time. I checked a few chat rooms & spoke to a customer who had an S5 with the same problem & the fix was to fit a new AC pressure sensor..£15, front bumper off, done.. fan not on any longer but still no AC... a quick £65 regas & it was sorted. Last week when the summer turned up, I obviously turned the temp down & the AC has been blowing very cold & then not so cold intermittently. In other peoples experience could it be low refridgerant & it needs a recharge? I hear they reuse the gas that they pull out including all the debris & moisture that have been taken out of all the cars that they do recharges on. Without plugging in & scanning for faults, has anybody had an experience similar & solved it? Quote Link to comment Share on other sites More sharing options...
