Has anyone with a new 2020 Q3 installed a dash cam themselves?
I'd like to be able to wire up a camera myself, but due to the large number of air bags and the lack of knowledge regarding the removal of the A pillar cover on this vehicle I may have to get an installer to do it for me
Anyone removed the A pillar cover safely and replaced it? I'd love to hear from you if you have
Thanks
My advice would be to get a professional to install it. But usually dashcam wiring is often piggybacked of the cigarette lighter/12v socket.
Steve
Steve
I don't have any worries about the actual wiring, it's not knowing how to safely remove the A pillar cover to route the cable behind the air bag that concerns me. I probably will get it fitted professionally in the end
  • 1 month later...
Hi Keith, are you enjoying your new car-I've聽called mine Suzi!聽(Suzi聽Q)聽the trims usually just prise off (have you got a 'trim removal tool')聽as I have done on previous聽cars but to be honest I haven't聽 looked into mine yet!聽I have also been thinking about fitting a dashcam, have you seen this model - IRO Dashcam it's very neat but doesn't seem available atm, it's advertised on Fb & Amazon!
Have you experimented with premium fuel at all? I will post the question聽as I am curious as whether there will be any gains in our Q3!
  • 3 months later...
Anyone reading this a few months on
You don't need to remove the A pillar cover completely to wire a dash cam, you can pull it out at the top just far enough to be able to get your fingers in and guide the wire BEHIND the air bag
Do you know how remove the dash end panel to get the cables to the fuse box in the glove compartment?
Yes, it鈥檚 just held on with clips
get a pry tool under the edge and carefully pry it off
  • 7 months later...
Hi Keith....if you manage to read this.
I hard wired my old Q3 and thought it would be easy on the new shape....in the end I couldn't fit the rear camera as I just couldn't get under the roof panel.
I didn't fancy trailing wires around the airbags!
I think I might have a go at fitting a separate standalone camera聽for the rear.
Regards
