Hey folks,just signed up need but if advice if possible.
I have a4 2.0tdi 2009 the power steering gets harder yo turn when the revs drop for corners and roundabouts,its fine otherwise,tyres are correct psi,fluid it as full as should be,any help appreciate
Peter
Could have sworn I've seen this issue already mentioned on the forum and believe it to be a sensor if I'm not mistaken. I'd get a diagnostic check carried out to see what fault codes flag up.
Steve
All sorted,not the fault code mate,the bottom of steering rack needed lubricated at the knuckle,that sorted it!
Picked up couple other fault code and fixed them so cheers for that!
